Schaller tuner - hole size
http://luthiersforum.com/forum/viewtopic.php?f=10101&t=16914
Author:  Chansen [ Fri Apr 18, 2008 1:35 pm ]
Post subject:  Schaller tuner - hole size
I am using the vintage Schaller tuners and am preparing to drill the holes. I have read every scrap of info in the archives and it looks like 10mm or 25/64" is the best bet for drilling the holes. My question though (and I'm having trouble interpreting in the archives) is can you use this bit all the way through? Or do you absolutely need to drill 1/4" first and then ream for the bushing. I am hoping to hear I can use the one-size bit straight through. This would leave the hole from the back side bigger than necessary - but with the tension on the bushing it seems like it wouldn't really matter. Correct me if I am wrong - my wife always does. duh
Author:  Rod True [ Fri Apr 18, 2008 2:34 pm ]
Post subject:  Re: Schaller tuner - hole size
Christian, I haven't used the vintage Schallers yet (I'd like to though) but I did find this review on the 13th fret about them.
Sounds like you drill the hole clear through (I use 25/64" drill for my Schaller tuners).
Author:  Mike Collins [ Fri Apr 18, 2008 3:21 pm ]
10mm all the way through !
Protect the wood the bit will come through with a wood caul clamped tight to it!
So you do not tearout that wood.
Al will be fine!
I've done hundreds of these! [:Y:]
After finishing the hole will have to be cleaned of finish -the hole will be smaller because of the finish build-up!
Author:  Allen McFarlen [ Fri Apr 18, 2008 5:41 pm ]
To clean the hole out of finish, just put the 10 mm bit in your drill chuck, and turn the chuck by hand.
Author:  Chansen [ Sat Apr 19, 2008 2:27 am ]
Thanks for the info - I used the drill press and the correct bit and it worked out just fine! Awesome.
