Second build and an opps call for help! http://luthiersforum.com/forum/viewtopic.php?f=10101&t=18417 |
Author: | zac_in_ak [ Sun Aug 17, 2008 2:02 am ] |
Post subject: | Second build and an opps call for help! |
well I am on my second kit build. This one I have to do quite a bit more then the first. It is a clone of the stew mac kit. ![]() ![]() 24 clamps is NOT enough good thing I got them at the borg for 37 cents ![]() ![]() I have been going ok but tonight I had a boo boo I am not sure how to fix. ![]() I put in the rosette and then came back later to plane it down and promptly tore off a chunk. I decided to pull out the rest and now I have no rosette. I could try my hand at making a wood one but don't think I can do a good enough job or maybe some colored epoxy.. any suggestions? ![]() |
Author: | bluescreek [ Sun Aug 17, 2008 7:14 am ] |
Post subject: | Re: Second build and an opps call for help! |
Rosettes are not hard. I learned not to do anything to the rosette until it is installed. Not to help you out ,what kind of rostette do you like? Wood is cool. I say try and make one , if that doesn't work out call for help. I can make a rosette as can alot of people here. We are here to help john hall blues creek guitars. Also check out GRIZZLY.com they have material as does stewart macdonald |
Author: | Jeremy Douglas [ Sun Aug 17, 2008 9:29 am ] |
See if you can order another rosette wherever you got the kit from. |
Author: | pnj [ Sun Aug 17, 2008 2:33 pm ] |
I just build that same kit. When i did the rosette, I used super glue and then a sanding block until I got the rosette down closer to the wood. Then I scraped with a razor until I was much closer. Then sanded the entire top piece. I think my approach stresses the rosette less, so there's less chance of it coming out. or maybe it was the super glue... ![]() I'd try some colored epoxie for a fix. Might be hard to sand flush though and it might leak out and stain the rest of the wood around the hole..... I guess I'm not much help... |
Author: | zac_in_ak [ Sun Aug 17, 2008 4:04 pm ] |
Someone suggested trying to make one in a patchwork pattern out of scrap and then I remembered some nice wood rosettes Ive seen in wood here so I think I may try to do one in wood or buy some veneer strips and trim them to size I will post pics of my fix when done. |
