Gold sparkle binding http://luthiersforum.com/forum/viewtopic.php?f=10101&t=19195 |
Author: | bigpigpeaches [ Tue Oct 14, 2008 10:16 pm ] |
Post subject: | Gold sparkle binding |
Anyone got any ideas on how to replicate it? Or even better, anyone who makes it? Thanks. |
Author: | tommygoat [ Wed Oct 15, 2008 12:27 am ] |
Post subject: | Re: Gold sparkle binding |
Gretsch? There was guy selling online few years back. Unfortunately, I can't remember that source. I'll look around... There was also someone that had a homemade recipe that was either in the G.A.L. publications -or- The Stew Mac Trade Secrets Book? Sorry to be so vague, but at least its a lead. Tom |
Author: | Howard Klepper [ Wed Oct 15, 2008 1:21 pm ] |
You might be able to cut it from stuff you strip off a drum. Gretsch drums used the stuff--probably where they got it for their guitars. |
Author: | JRE Productions [ Thu Oct 16, 2008 4:04 pm ] |
Call DrumWraps. They will sell you a sheet of gold sparkle wrap. It about .060 thick, so you will need to use other binding with it. They told me they can sell cut offs (I was looking at the pearl stuff), but the do sell sheets long enough for bass drums. You will have to cut it on the bandsaw yourself. I think they are out of the west region...maybe arizona or colorado.. Joe |
Author: | bigpigpeaches [ Fri Oct 17, 2008 12:23 am ] |
JRE Productions wrote: Call DrumWraps. They will sell you a sheet of gold sparkle wrap. It about .060 thick, so you will need to use other binding with it. They told me they can sell cut offs (I was looking at the pearl stuff), but the do sell sheets long enough for bass drums. You will have to cut it on the bandsaw yourself. I think they are out of the west region...maybe arizona or colorado.. Joe This is greatness. Thanks a bunch, I didn't even think of that, but now that you mention it, I seem to remember hearing that Gretsch cut their bindings out of the same wrap material that their drums were coated with. ![]() |
Author: | Saul Koll [ Fri Oct 17, 2008 10:15 pm ] |
This is where I get what I use: http://www.precisiondrum.com/html/sparkles.html It is tricky around the tight radius bends. It likes to delaminate in those areas. You can saturate it back together with super glue. One thing I found out is that you need to put a barrier coat of something before nitro. Nitrocellulose lacquer will make it craze, and not in a cool way. I spray a two part poly over it, let it cure for a couple days, scuff it, and then continue on with my normal lacquer routine. Another tricky deal with this stuff is that the color coat is a very thin layer and easy to go through. Around the body this is not too much of an issue, but on the fingerboard edge, it is difficult to complete the edge of your fingerboard in a comfortable way. You have to leave this stuff alone, and can't radius or shape it like a normal celluloid or ABS binding. Good luck! Here is a guitar I used this stuff on: ![]() |
Author: | ChuckH [ Sat Oct 18, 2008 12:14 am ] |
Wow Saul, That is a beautiful guitar. Nice job. |
Author: | Saul Koll [ Sat Oct 18, 2008 10:13 pm ] |
Thank You Chuck! It was my take on a White Falcon or Penguin. Cheers, Saul |
Author: | Hesh [ Sun Oct 19, 2008 6:39 am ] |
Saul welcome to the OLF! ![]() ![]() ![]() ![]() That is a beautiful guitar and I would not mind seeing more of it if you would post more pics please? |
Author: | Tai Fu [ Sun Oct 19, 2008 9:36 am ] |
Instead of using cat poly which is nasty why not spray first with KTM-9 or other waterbased finish before spraying on lacquer? |
Author: | Saul Koll [ Mon Oct 20, 2008 4:33 pm ] |
Hesh wrote: Saul welcome to the OLF! ![]() ![]() ![]() ![]() That is a beautiful guitar and I would not mind seeing more of it if you would post more pics please? Thanks so much. This is an amazing forum. So much talent and ideas here. Here are a couple more shots of that guitar: ![]() ![]() ![]() And here is a guitar with the same material on the top. I used a vacuum bag to glue it to the carved surface: ![]() I still use it for bindings on Gretschy sort of things, but for tops, I now prefer to spray the flake, rather than use this drum wrap. I had one instrument returned because of delamination. It was on a stand on the stage at an out door summer concert. It bubbled up a little... It was a pain to remove: ![]() It came off only in little chips |
Author: | Saul Koll [ Mon Oct 20, 2008 4:37 pm ] |
rahimiiii wrote: Instead of using cat poly which is nasty why not spray first with KTM-9 or other waterbased finish before spraying on lacquer? That might work, but I haven't tried it. I used what I normally have in the shop. I thought about trying a simple shellac mix as a barrier. That might do the trick as well. I don't understand the chemistry of the reaction I was getting. When used for drums, it is not normally over coated. The untouched surface of this material is quite shiny. But in my case, I wanted a continuous film over the back and sides, bindings etc and decided to put my finish on it. |
