| Cardboard on back of inlays? Need help with first time. http://luthiersforum.com/forum/viewtopic.php?f=10101&t=19366 |
| Author: | JRE Productions [ Tue Oct 28, 2008 8:59 am ] |
| Post subject: | Cardboard on back of inlays? Need help with first time. |
Hello again! I am working on #2. I decided to add an inlay to the headstock. I bought a nice simple inlay that is multiple pieces. It came glued to a piece of cardboard. I assume I need to cut around the inlay leaving the cardboard on it to hold it together. (yes?) But I also think it is face up on the cardboard (its symetrical..so it probably doesn't matter). How would you guys suggest I go forward with the inlay. I have done fingerboard inlays that were all one piece, so I have the basic process down...but I am not sure what to do with this one. Thanks for any help! Joe |
| Author: | JRE Productions [ Tue Oct 28, 2008 9:00 am ] |
| Post subject: | Re: Cardboard on back of inlays? Need help with first time. |
| Author: | LanceK [ Tue Oct 28, 2008 9:03 am ] |
soak it in water and it will fall off the chipboard |
| Author: | JRE Productions [ Tue Oct 28, 2008 9:13 am ] |
Will the inlay seperate? I don't think they are glued together. So the plan would be to trim the inlay on the cardboard to use as a template. Route my cavity. Soak the inlay to loosen the cardboard. Then either add glue and then place in the inlay...or lay the inlay in the correct spot and add CA....yes? |
| Author: | Rod True [ Tue Oct 28, 2008 9:17 am ] |
Joe, follow this from Andy DePaul and you won't go wrong. |
| Author: | JRE Productions [ Tue Oct 28, 2008 10:03 am ] |
Rod True wrote: Joe, follow this from Andy DePaul and you won't go wrong. Excellent TUTE! Thanks a bunch. I am now ready to move forward with this tonight and get it right! JD |
