Soundboard joining clamp
http://luthiersforum.com/forum/viewtopic.php?f=10101&t=19381
Author:  Alan [ Tue Oct 28, 2008 6:56 pm ]
Post subject:  Soundboard joining clamp
Just joined the soundboard for the OM I was starting, but when I got it out of the clamps, I noticed that it had shifted (one half a little high). By the time I got it sanded down even, it ended up being a thin and flexible .083 -.085 thick.
I went ahead and inlaid the abalone rosette, but then decided that I didn't want to take the chance with one that thin, so started over. After I jointed the edges on this one, I glued it up only using binding tape to pull the halves together rather than my clamp setup. That was very quick and worked great! The halves pulled up good and tight and remained flat. I did clamp a caul accross the seam to make sure it didn't shift, but believe that it would have been fine without it. It worked so well that I might adopt this method going forward.
Author:  Alain Moisan [ Tue Oct 28, 2008 7:34 pm ]
Post subject:  Re: Soundboard joining clamp
Since we are on the subject, here is my method. Works well too.
Author:  Don Fera [ Tue Oct 28, 2008 9:09 pm ]
That is a sweet setup! Very elegant and balanced. I like the way that there is distributed downward clamping force to hold the plates flat and in alignment. Do you use two different sized jigs for steel strings and classicals? Or do you find that one size is adequate for both?
Thanks.
Author:  Alan [ Wed Oct 29, 2008 6:59 am ]
Very Nice Alain! I must say that is a much more elegant approach!
Author:  Alain Moisan [ Wed Oct 29, 2008 10:18 am ]
Thanks for the nice comments guys!
No, I only have one jig for all the three models I offer. You can not see it well on the picture, but there are multiple holes where the cams can be inserted, thus adapting to several size boards.
Note that I intend to eventually replace the cams with wedges. Easier and faster.
Author:  Nelson Guitars [ Wed Oct 29, 2008 10:44 am ]
This one is classic and hasn't failed me yet!
Just glue up, rope up and push the wedges in. There is room for cleaning the excess glue off and it's open enough to inspect the joint as you go. It also stores away in a very small space.
Greg N
Author:  Alain Moisan [ Wed Oct 29, 2008 3:50 pm ]
Yes indeed this setup works very well. I needed to go a step further in my design since my drum sander will only accept one half at a time. So since I have to get the halfs to final thickness before joining them, I needed a setup that would insure a joint that doesn' move AT ALL when gluing. The result if fine; I just have to scrape the glue squeeze out when done.
Author:  John How [ Wed Oct 29, 2008 4:50 pm ]
My setup is very similar to Gregs, the nice thing is it accepts tops and backs of all sizes and shapes. Many times you get a top or back that is not nice and rectangular but it doesn't matter with this jig.
Author:  Sylvan [ Wed Oct 29, 2008 6:50 pm ]
Heavy duty masking tape and hide glue. You do not need anything else. No seams. Works great.
Author:  SimonF [ Wed Oct 29, 2008 8:01 pm ]
+1 to what Sylvan said. I use binding tape and it works great.
Author:  Glenn LaSalle [ Thu Oct 30, 2008 8:33 am ]
This is the method I am using, and it has been working well for me:
Glenn
