Tortoise celluloid nitrate revisited http://luthiersforum.com/forum/viewtopic.php?f=10101&t=20597 |
Author: | Brad Goodman [ Tue Jan 20, 2009 2:39 pm ] |
Post subject: | Tortoise celluloid nitrate revisited |
I am about to bind a guitar with tortoise celluloid nitrate. I searched the archives and found a few threads on it. I am using .070 thick for the body binding,heel cap and head veneer. Some of the info I found said to install a white wood purfling behind it to make it stand out more-is this the general consensus? If you do use a pufling behind it,what type ofglue do you use? The body and neck are Honduran mahogany. Thanks, Brad |
Author: | Barry Daniels [ Tue Jan 20, 2009 2:52 pm ] |
Post subject: | Re: Tortoise celluloid nitrate revisited |
The tortise shell is kind of transparent so you will slightly see whatever is behind it. If you have rosewood sides and a spruce top, this two-tone effect for the top binding may look a little weird. On my last guitar, I installed a .010" layer of white plastic behind the tortise shell and it really made it pop. If you don't do this, it will look considerably more muted. |
Author: | Michael Dale Payne [ Tue Jan 20, 2009 3:03 pm ] |
white abs plastic behind the it use Duco as the adhesive. |
Author: | Howard Klepper [ Tue Jan 20, 2009 3:12 pm ] |
I use white celluloid from StewMac. It glues better than ABS. Weld On is somewhat stronger than Duco. CA works very well. But you can even use a PVA glue if you first wipe with acetone, which seems to open up the surface for adhesion to a glue that is intended for porous surfaces.. |
Author: | TonyKarol [ Tue Jan 20, 2009 4:23 pm ] |
I only ever used it on FBs .... I put maple veneer behind it. |
Author: | Brad Goodman [ Tue Jan 20, 2009 4:35 pm ] |
Thanks for all the replies. I am thinking of using maple or holly behind it. So would the weldon glue work for the wood to wood joint as well as the wood to tortoise joint? |
Author: | Laurent Brondel [ Thu Jan 22, 2009 8:35 am ] |
CA works the best IMHO, it will also make the joints invisible. |
