Digital Accuracy with the Stewmac Rosette Channel Cutter :) http://luthiersforum.com/forum/viewtopic.php?f=10101&t=20812 |
Author: | Bob Garrish [ Sun Feb 01, 2009 7:32 pm ] |
Post subject: | Re: Digital Accuracy with the Stewmac Rosette Channel Cutter :) |
Very nice. I'd give you a whole page of those clappy emoticons if I were into that sort of thing ![]() |
Author: | Hesh [ Sun Feb 01, 2009 7:44 pm ] |
I resemble that remark..... ![]() Dave my friend this is too cool!!!!! If I could purchase one I most certainly would! ![]() ![]() ![]() ![]() ![]() ![]() |
Author: | ChuckH [ Sun Feb 01, 2009 11:35 pm ] |
That is just too cool. What a concept. Brilliant! |
Author: | Joe Sabin [ Sun Feb 01, 2009 11:48 pm ] |
You read my mind, I'm in the process of attaching a 1/64" scale to my StewMac Rosette Channel Cutter, I thought it needed to be more accurate. I may pause my progress and adopt your method. Cool! |
Author: | Dave Fifield [ Tue Feb 03, 2009 5:19 am ] |
Glad it interested a few people at least. Joe, please post piccies of your conversion when you get it done. I may re-design the whole base/dremel holder using laser-cut acrylic and incorporate a better digital scale (that reads radius directly - center of router bit to center of circle) into it....we'll see - depends on how much free time I can treat myself to in the next few weeks. Cheers, Dave F. |
Author: | Darrin D Oilar [ Tue Feb 03, 2009 6:18 pm ] |
Very cool. As a tip, I don't think you annealed it when you heated and then quenched it. I believe you hardened it. I may be wrong regarding stainless, but with high carbon steels you anneal by heating very hot then allowing to cool slowly. The slower the better. Darrin |
Author: | jordan aceto [ Tue Feb 03, 2009 6:42 pm ] |
Darrin D Oilar wrote: Very cool. As a tip, I don't think you annealed it when you heated and then quenched it. I believe you hardened it. I may be wrong regarding stainless, but with high carbon steels you anneal by heating very hot then allowing to cool slowly. The slower the better. Darrin I just did some quick internet research, and it seems like the process for annealing stainless is backwards( hot -> quench = anneal), and that stainless is only hardenable by work hardening. Cool, something new everyday. Really cool mod Dave F.! |
Author: | Terry Stowell [ Tue Feb 03, 2009 6:55 pm ] |
I watched a DIY network video on Lynn Dudenbostel making mandos or guitars. I showing a dial indicator (not caliper...) on his. Not sure how it was mounted, but it's easy enough to do |
Author: | Darrin D Oilar [ Tue Feb 03, 2009 7:07 pm ] |
jordan aceto wrote: Darrin D Oilar wrote: Very cool. As a tip, I don't think you annealed it when you heated and then quenched it. I believe you hardened it. I may be wrong regarding stainless, but with high carbon steels you anneal by heating very hot then allowing to cool slowly. The slower the better. Darrin I just did some quick internet research, and it seems like the process for annealing stainless is backwards( hot -> quench = anneal), and that stainless is only hardenable by work hardening. Cool, something new everyday. Really cool mod Dave F.! Jordan: I just looked too. Like you said, learn something new. Weird that it is backwards. I would have never thought that. I stand corrected Dave, you were right on the money from the get-go. Darrin |
Author: | Blain [ Tue Feb 03, 2009 7:14 pm ] |
Great job Dave, and very innovative! |
Author: | Joe Sabin [ Wed Feb 04, 2009 4:24 pm ] |
There's also a special oil you can use to quick cool steel to put a less brittle finish to the steel. My dad was a tool&die maker and used to show me the various tool finishes based upon how he hardened them. Remember hardened steel is hardened on the surface, the interior is not as hard because it cooled slower. I think there are also water treatments you can use to create different surface hardness. I was facinated as a kid to learn my dad could make a piece of steel too hard to machine, then make it soft again to machine it again. Also all this heating and cooling changes the size of the object. Of course it's in the thousandths, but still, might matter, it did to him. |
Author: | Bob Garrish [ Wed Feb 04, 2009 5:22 pm ] |
To put pulleys on shafts, and also in other tool-holding applications, they make use of that. On the Fadal the pulley that spins the spindle is put on that way; to take it off you need to heat it up with a torch. |
