Finally Done!!! (pics) http://luthiersforum.com/forum/viewtopic.php?f=10101&t=21278 |
Author: | Frank Aarre [ Sun Mar 01, 2009 5:20 pm ] |
Post subject: | Finally Done!!! (pics) |
No, haven't finished my first guitar yet( barely started it), but i have finished quite a few jigs and machines, the latest my drum sander. what started out as a simple plan for a drumsander made out of wood quickly changed as my career did. I am now a part owner of a full metal shop, so it only made sense to modify my drum sander plans to be made out of steel. i just gave ot a test drive on some cedar and some cherry just before taking the pictures and the results were very pleasing. pay no attention to the background clutter.(i've been meaning to take care of that) so without further ado here are the pics. Attachment: front.jpg Attachment: side.jpg Attachment: back.jpg Attachment: side2.jpg Attachment: belt cover.jpg Attachment: heightadjustment.jpg Attachment: gearmotor-controlpanel.jpg
Author: | Randolph [ Sun Mar 01, 2009 5:54 pm ] |
Post subject: | Re: Finally Done!!! (pics) |
Wow!! Frank, awesome sander. ![]() |
Author: | oli-lgw [ Sun Mar 01, 2009 5:57 pm ] |
nice! just out of curiosity, how do you set the thickness? (I can't seem to see anything to either raise/lower the sander nor the table) ![]() ![]() ![]() |
Author: | Frank Aarre [ Sun Mar 01, 2009 6:09 pm ] |
olivier, if you look at the picture named height adjustement, you see 3 threaded rods connected with sprockets and roller chain, you also see that one of the threaded rods extend beyond the mounting point that's what i turn on to adjust the height i've been meaning to attach a wheel to the end of that rod for easy adjustment. the 'legs' on the feed table is of such dimesion that it fits into the legs of the base, so they slide in the base, you can the same principle being used on the motor mounts for easy belt tightening. And yes i've got a pile to push through it ![]() edit: i also drilled and tapped the sprockets and fatsened them with a nut, so if in need of fine tuning on just one of the rods i just loosen the nut that locks the sprocket and turn just that one rod. |
Author: | Lillian F-W [ Sun Mar 01, 2009 8:31 pm ] |
Well done Frank. It looks great. Are you happy with it? |
Author: | Dennis Leahy [ Sun Mar 01, 2009 9:48 pm ] |
Frank, That is one really nice looking shop-built sander. It looks really well engineered and built. Good job! Dennis |
Author: | Steve Kinnaird [ Sun Mar 01, 2009 10:27 pm ] |
Ho Lee Kow. What a tool.... |
Author: | Rod True [ Mon Mar 02, 2009 12:01 am ] |
Frank, that looks great. Now, don't change your mind on your body mold just because you own a steel fab shop. Stick with wood for that ![]() |
Author: | Stephen Boone [ Mon Mar 02, 2009 1:15 am ] |
That is one neato torpedo sanding device!! I would hardly call that shop cluttered. |
Author: | ChuckH [ Mon Mar 02, 2009 2:23 am ] |
Wow Frank, that looks like something you buy from a factory. Great Job! |
Author: | CraigSz [ Mon Mar 02, 2009 3:49 am ] |
Way to go Frank. ![]() ![]() Regards Craig. |
Author: | Rich Schnee [ Mon Mar 02, 2009 6:14 am ] |
Frank...it looks great. Steel is real... |
Author: | Lars Stahl [ Mon Mar 02, 2009 8:30 am ] |
Grattis Frank. underbart bygge !! Great work !! Sincerely Lars. |
Author: | Frank Aarre [ Mon Mar 02, 2009 10:01 am ] |
thanks for the kind words. Rod, luckily i built the molds and forms while i was employed as a carpenter, so yes they are wood. i have never used a thickness sander before so i wasn't quite sure what performance to expect, but i must say i was pleasantly surprised. i thicknessed those pieces of cedar you see in the pics from an uneven 10mm thickness down to 5mm in just a couple of minutes and they came out with a tolerance of +- 0.03mm. i'm sure it will take a lot more passes to get that tolerance with hardwood though. well Craig if you pay for the shipping from norway to australia..... |
Author: | SteveSmith [ Mon Mar 02, 2009 12:35 pm ] |
shipping from norway to australia..... Might me enough to buy a small car. ![]() Seriously, that is a very nice looking unit. One of the things that has held me back from making my own is the feed unit. What did you use for the feed belt, feed rollers, and what size/speed is you gear motor? |
Author: | Frank Aarre [ Mon Mar 02, 2009 2:08 pm ] |
Steve, i've been very lucky as far as parts for this sander goes, everything was found in our shop except for the feed belt. the gear motor(0,25kw 1,32A) has got quite the powerful gear on it, a reduction from 1400 rpm to 12 rpm and with my rollers that works out to about 3m/min( around 9-10 feet pr min). the rollers were parts taken from an old conveyor system. the feed belt i got custom cut and joined from a local outfit that specialises in wheels and belts for most industry transport needs, was expensive but worth it i think. its thick enough to get good cushioning so that i can set quite a bit of pressure on the drum. |
Author: | CraigSz [ Tue Mar 03, 2009 5:44 am ] |
Well Frank I did a few rough calcs. 1 set of back and sides hand sanded to final thickness from .130 . One top the same. Approx 20 Hrs at $50/Hr Package it up as soon as you can ![]() Craig. |
Author: | John Hale [ Tue Mar 03, 2009 6:55 am ] |
I'm green with envy ![]() |
