| Guess the finish ! :-) http://luthiersforum.com/forum/viewtopic.php?f=10101&t=21860 |
Page 1 of 2 |
| Author: | Lars Stahl [ Wed Apr 08, 2009 7:49 pm ] |
| Post subject: | Guess the finish ! :-) |
Ok so I have started to put on a finish on the body and neck. of my nr 2. Nr 1 is still curing from the French polish. (allthough not all done yet. Seems like its taking me forever to finish these guitars. Its harder the further you go. I have a faux-bound fretboard and I need to buy a fretnipper or something like that. Or if someone has any good advice, feel free to let me know. I am also in the progress of getting some nut files etc. and last but not least a reamer !! Money money money. But no winning on the lottery hmm. So to the question. lets see what you think. I have put on 3 coats of finish so far . Can you guess what kind ?? Lars. Attachment: finish2.jpg Attachment: finish.jpg Attachment: finish3.jpg
| Author: | Mike OMelia [ Wed Apr 08, 2009 7:58 pm ] |
| Post subject: | Re: Guess the finish ! :-) |
Water based? |
| Author: | Joe Sabin [ Wed Apr 08, 2009 8:42 pm ] |
EmTech 6000 |
| Author: | Lillian F-W [ Wed Apr 08, 2009 8:48 pm ] |
Tru-oil? |
| Author: | Jeremy Douglas [ Wed Apr 08, 2009 9:11 pm ] |
Lillian F-W wrote: Tru-oil? +1 |
| Author: | SteveSmith [ Wed Apr 08, 2009 9:14 pm ] |
Joe Sabin wrote: EmTech 6000 +1 |
| Author: | Bill Hodge [ Wed Apr 08, 2009 9:20 pm ] |
Joe Sabin wrote: EmTech 6000 +2
| Author: | StevenWheeler [ Wed Apr 08, 2009 9:25 pm ] |
Looking good so far Lars. I'm going to guess Tru-Oil also. On the frets, clip the tang as close as you can with the tool you are using to cut the fret wire to length and then use a three corner file to remove the rest. It takes some time but works well. Steve |
| Author: | Steve Kinnaird [ Wed Apr 08, 2009 10:17 pm ] |
Lard? JJ |
| Author: | Zach Ehley [ Wed Apr 08, 2009 10:34 pm ] |
Tru-oil. Your were trying to find it in Sweden a few days ago! Found it at a gun shop...or I should say veapons. viewtopic.php?f=10101&t=21739 Looks good. |
| Author: | Lars Stahl [ Thu Apr 09, 2009 6:26 am ] |
HAHAHA Thanks Zach !! . Yes True-oil it is. I really love it. easy to put on and no hazzle. Allthough I only have FP to compare with hahaha. But it look great so far, it does not have the same "Shine" on the top though , hmm. but looks great. Will put on the last coat tonight I think. If anyone has any good pointers or trick for true-oil then let me know. 3 coat s so far, should I put on 4 ? or is 3 enough. Steve, Great tip ! thanks, will try it right away. Lars. |
| Author: | walnut47 [ Thu Apr 09, 2009 8:18 am ] |
Lars, Did you put shellac down under ther Tru-oil? Walter |
| Author: | Lars Stahl [ Thu Apr 09, 2009 9:55 am ] |
Yes I did, allthough, I put a bit to much At first so I sanded some off and then put on the true-oil. |
| Author: | Jamie Burgess [ Thu Apr 09, 2009 1:53 pm ] |
Hey Lars, That looks awesome. What was your finishing schedule? How did you apply the true oil? Did you buff this out? Again, it looks great. Jamie |
| Author: | Frei [ Thu Apr 09, 2009 6:44 pm ] |
Lars, hope you didn't leave the speaders in the box! I just got some nice handplanes, so dont complain about the $$ (LN small scraper plane, ECE toothed plane_) Great for taking down wood, without killing your hands too much_)...I saw something on Stewie mac, about a peghead drill bit, so you dont use a reamer, but you have to size it to your tuners.... |
| Author: | Lars Stahl [ Thu Apr 09, 2009 9:30 pm ] |
Quote: Lars, hope you didn't leave the speaders in the box! I DID !!!! Allthough, I had made the soundhole a little larger than normal and was able to get em out hahaha. hmm. But as I realized it I was totally Freakt out hahahaha. Thanks Jamie. No buffing yet. I put down 3 coats. 1st coat - waited over night. 2nd coat then waited about 3 houers until it felt about dry "enough" same for 3rd. Between all coats I used 0000 steel wool with light strokes to take off any wrongs. Now I will let in hang for a few weeks and then see what it feels and looks like and then polish it. I aplied the oil with cotton rags. Lars. |
| Author: | Frei [ Thu Apr 09, 2009 9:41 pm ] |
I be working on some "easy remove" (back glue-on )spreaders for this type of emergency! So you can still brace again th mold..!
| Author: | Matthew Jenkins [ Fri Apr 10, 2009 6:12 am ] |
Lars, 3 coats of Tru Oil seems quite minimal. I think you would need at least 9. I put about 12 coats of tru-oil on the B&S of this guitar. One in the morning and one before bed, repeat. I gently levelled every day with 0000 wire wool, buffed out with micro mesh and finished with meguiars polish. Cheers Mat |
| Author: | Lars Stahl [ Fri Apr 10, 2009 7:47 am ] |
WOW, thanks for the tip. Will put a few more on then... Lars |
| Author: | Grant Taylor [ Fri Apr 10, 2009 6:31 pm ] |
Looks good so far Lars, I love tru-oil also. Although it marks easily so I'm always very careful with the instrument..but its a good sounding finish. I used 2 coats of z-poxy as a sealer on the whole instrument (and I wonder in hindsight whether the face needed any sealing at all as the tru-oil doesn't seem to penetrate much) Anyway what I wanted to say is I put down about 15 coats of oil sanding in-between and looking at it now I really could have put down another 5 or 10. Beauty of it is its ease of use but very time consuming finish with the waiting time. ![]() ![]()
| Author: | jmpbuffalo [ Sat Apr 11, 2009 9:20 pm ] |
Hi, not to hijack this topic, but what solvent do you all use when rubbing out tru-oil with micromesh? And, how long do you let it wait before polishing? BTW, I tried searching on "tru-oil" and got no matches at all. Don't know if the search feature is working properly. Thanks, Joe |
| Author: | Lars Stahl [ Sat Apr 11, 2009 10:00 pm ] |
Search "trueoil" also some olive oil on wet/dry micromesh i think. http://www.lmii.com/CartTwo/TruOil.htm Lars |
| Author: | Frei [ Sat Apr 11, 2009 10:22 pm ] |
Isnt trueoil supposed to be a week between coats? C'mon, good enough....string that baby up Lars....!! Spit coat, then the strings on mine, same day, promise! |
| Author: | jmpbuffalo [ Sun Apr 12, 2009 8:10 am ] |
Thanks, Lars. Joe |
| Author: | Lars Stahl [ Sun Apr 12, 2009 11:16 am ] |
I am soon there Frei HAHAHA . I am waiting for some tools . All is going so well, so I dont want to do something to fast now as then if I screw up I will for sure find me the highest building and do a swan dive hahahaha. Lars |
| Page 1 of 2 | All times are UTC - 5 hours |
