slotted headstock angle?
http://luthiersforum.com/forum/viewtopic.php?f=10101&t=22188
Author:  Josh H [ Thu Apr 30, 2009 10:46 am ]
Post subject:  slotted headstock angle?
I’m in the process of finishing up the design work for my first slotted headstock guitar. I’m just wondering if the peghead angle for the slot headstock is the same as for a solid headstock or is it a lot different? Right now I am using 14 degrees.
Josh
Author:  Richard G [ Thu Apr 30, 2009 11:24 am ]
Post subject:  Re: slotted headstock angle?
Hi Josh,
I have plans for a OOO slot head that calls for a 10 degree headstock angle. From what I understand, a 15 degree angle would be on the steep side since the break angle for the strings is to the middle thickness of the headstock rather than the post sitting on top.
Author:  Jimmy Caldwell [ Thu Apr 30, 2009 12:21 pm ]
Josh,
Unless you're trying to replicate a vintage instrument of some kind, 14 degrees works fine. There's nothing wrong with a steeper break angle at the peghead. I've built guitars with a 30 degree scarfed peghead without any problems.
Author:  Wade Sylvester [ Thu Apr 30, 2009 1:01 pm ]
I'd draw it out on paper to see if 10 degrees will yield an average 15 degree string angle on a slotted head stock but I suspect this is a rule of thumb not written in stone, so-to-speak.
Intuition tells me better to be more of a break angle than under.
Author:  Mike Collins [ Thu Apr 30, 2009 1:30 pm ]
I use 10 degrees also.
For the very reason Richard stated.
Plus it looks right also.
Author:  Mike Collins [ Thu Apr 30, 2009 1:34 pm ]
The strings will ride on the wood ramps if the angle is steep.
Removing more wood there to compensate will weaken the area .
Author:  TonyKarol [ Thu Apr 30, 2009 2:06 pm ]
Do I hear 11 ... going once ... thats right, goes to 11 ....
Author:  woody b [ Sat May 02, 2009 10:45 am ]
I always assumed the angle was the same. I made my 12 fret neck template from a slothead Martin I was doing a neck reset on. I'll have to check and see what the angle is.
Author:  vachterman [ Sat May 02, 2009 3:08 pm ]
i once came across an article by Mr.Somogyi about the guitar's neck and it's design.
he stated that 10 degress on a slothead os what he uses and so thats what i've been using ever since though funnily enough that didnt make my guitars sounds like his ;)
Author:  Josh H [ Sat May 02, 2009 9:38 pm ]
Thanks guys, it is helpful to know what others are doing. I see the logic in using the 10 degree angle and I think that is what I will try first.
Josh
