Pores Again
http://luthiersforum.com/forum/viewtopic.php?f=10101&t=22435
Author:  StevenWheeler [ Wed May 20, 2009 10:20 am ]
Post subject:  Pores Again
I pore filled my current build with Stew-Macs Color Tone clear pore filler and didn't do as god as a job as I thought. After the first six coats of Nitro and sanding, I'm seeing quite a few pores that won't be filled with lacquer any time soon. What's the best way to fill these? I was thinking of trying CA over the lacquer after allowing it to cure for two weeks. Is that a waste of time? Would it be better to strip the lacquer and start over?
Author:  Barry Daniels [ Wed May 20, 2009 10:41 am ]
Post subject:  Re: Pores Again
No, do not put CA over the lacquer. That would be a mess.
I would try sanding the lacquer down and applying more coats. The pores should fill with the lacquer eventually.
Author:  StevenWheeler [ Wed May 20, 2009 11:06 am ]
Thanks Barry,
I think I'll drop fill the 5 or 6 big ones and then continue with the lacquer.
Author:  TonyKarol [ Wed May 20, 2009 11:17 am ]
Even with no pore filler at all, 8-10 coats of lac will be enough to fill them once you sand back. Then add another 5-6 and let cure.
Author:  woody b [ Wed May 20, 2009 11:37 am ]
If there's only 5 or 6 big ones just drop fill them with lacquer. I'm pretty good at pore filling but I've always had a few places to drop fill in between coats.
