Gluing up a stacked heel http://luthiersforum.com/forum/viewtopic.php?f=10101&t=23630 |
Author: | WaddyThomson [ Sun Aug 30, 2009 10:06 pm ] |
Post subject: | Re: Gluing up a stacked heel |
I just used plywood cauls on the sides with tape on them, to keep the glue from sticking. Seemed to work fine. |
Author: | Lillian F-W [ Sun Aug 30, 2009 10:15 pm ] |
Filippo, Robbie's video on making neck blanks shows two methods that are quick and easy. |
Author: | Marc [ Mon Aug 31, 2009 6:57 am ] |
1/8 inch dowels in the corners, the dowel in the lower left corner is hard to see because it's still in. Attachment: heel.JPG
Author: | David Newton [ Mon Aug 31, 2009 11:55 am ] |
You must be using titebond, the slippin'est glue around. Hide glue tacks real fast. Of course if you are looking for perfect alignment, you'll want dowels of some sort. |
Author: | meddlingfool [ Mon Aug 31, 2009 3:43 pm ] |
somebody once showed me to do it sort of like a spanish heel, just run the whole stack through the tablesaw against the fence top to bottom with a very shallow cut in the excess, flip it and do the other side, then use a piece of sidescrap in each slot to keep things stable. I've never actually done it but it seemed to work for him... |
Author: | george wilson [ Mon Aug 31, 2009 10:19 pm ] |
You could just glue the blocks on one at a time. I never had a problem with them sliding. |
