Solid color finishing
http://luthiersforum.com/forum/viewtopic.php?f=10101&t=24037
Author:  tommcloughlin [ Sun Oct 04, 2009 9:20 am ]
Post subject:  Solid color finishing
I am building a dobro like guitar from a kit which uses birch plywood. I want to finish it solid black. I have some experience with spraying clear laquer but none with colors. My main concern is how to deal with keeping the color off the binding .
Author:  jackwilliams [ Sun Oct 04, 2009 9:34 am ]
Post subject:  Re: Solid color finishing
If you are using plastic binding, you can spray over the binding and then scrape ( with a razor blade) clean, or you can mask off with good quality masking tape.If you are using wooden binding I'd suggest masking; Either way, you'll probably want to spray clear coats over the color coats after you remove the overspray or the tape.
regards,
jack
