Best place to buy sandpaper for drum sanders. http://luthiersforum.com/forum/viewtopic.php?f=10101&t=26706 |
Author: | ChuckH [ Fri Mar 26, 2010 7:09 am ] |
Post subject: | Best place to buy sandpaper for drum sanders. |
I have a Performax 10-20 and a Delta 18-36. Where would you guys and gals recommend buying grit for the drum? Thank you in advance. Hutch |
Author: | Brad Goodman [ Fri Mar 26, 2010 8:27 am ] |
Post subject: | Re: Best place to buy sandpaper for drum sanders. |
Hi Hutch, I used Klingspor when I had a drum sander. They sell it precut,pre-marked and bulk..They are a great supplier of all things related to sandpaper. Regards, Brad |
Author: | ChuckH [ Fri Mar 26, 2010 8:31 am ] |
Hey Brad, Thanks for the tip, I'll go check them out now. So, you don't use a drum sander anymore? You hand planing now, what's your secret? Thanks, Hutch |
Author: | Robbie O'Brien [ Fri Mar 26, 2010 9:09 am ] |
I recently bought a bunch from woodworker's supply. They had a special on it and with the contractor's discount it was very reasonable. I got about 3 rolls of 80 grit and 3 rolls of 120 grit for a steel city 26 inch dual drum sander and if I remember correctly it was under 50 bucks including shipping. |
Author: | Laurent Brondel [ Fri Mar 26, 2010 11:50 am ] |
I get 3" rolls from Klingspor as well, inexpensive and good quality, and cut to length for the 10/20 as needed. They also sell the conveyor belts for the 10/20. |
Author: | Kent Chasson [ Fri Mar 26, 2010 12:15 pm ] |
I got some from Grizzly once that was surprisingly good. I was out of paper and they are right down the street. All they had in stock was the kind that's backed for hook and loop. I was worried that, with the extra padding, it wouldn't sand flat. It sanded fine and I came to believe that it actually helped dissipate heat and made the paper last longer. |
Author: | Arnt Rian [ Fri Mar 26, 2010 12:25 pm ] |
Kent, I too use furry-backed hook and loop type paper on my sander, and I also think the "cushioning effect" is helpful. I buy large rolls of 6" Klingspor paper, and cut them up as needed. I wish I could remember where I bought it... |
Author: | Alan [ Fri Mar 26, 2010 12:37 pm ] |
I bought mine here: http://www.supergrit.com/products/produ ... -cloth.asp |
Author: | Mike Collins [ Fri Mar 26, 2010 1:06 pm ] |
Try www.industrialabrasives.com Mc |
Author: | JohnAbercrombie [ Fri Mar 26, 2010 2:38 pm ] |
What Mike said: Another vote for industrialabrasives here.... Good service via USPS to Canada, too. John |
Author: | Darrel Friesen [ Sat Mar 27, 2010 9:56 am ] |
I buy 50 yard rolls of the 2" Klingspor at Canadian Woodworker for less than $50 a roll for my 18-36. |
Author: | David R White [ Sat Mar 27, 2010 1:18 pm ] |
Another vote for Industrial Abrasives, their premarked rolls for the Delta are good value. |
