It is currently Tue Jun 09, 2026 7:42 am
PostPosted: Thu Apr 22, 2010 3:43 am
First name: Martin
Last Name: Kominak
Country: Slovakia
I want to build my first flamenco guitar - a negra, but I only have a plan for blanca.
How do I need to alter my plan to build the guitar successfully? Just use indian rosewood instead of cypress for b/s and follow the plan as it is? I read somewhere that rosewood back should be thinner than cypress back?
PostPosted: Thu Apr 22, 2010 5:40 am
Country: Romania
If I was doing it, I would probably make the back 1.8-1.9mm (or 2mm in the center and 1.8 on the outer zone) and the sides about 1.5-1.6mm. All this combined might still be heavier than cypress. But if made thinner, it probably becomes too much of a structural gamble, even if flamencos are supposed to be played to death. It also depends on how solid and dense your rosewood is...
Good luck anyway! [:Y:]
Build log
PostPosted: Thu Apr 22, 2010 6:23 am
I agree with Alexandru on back and side thickness. I also glue "costillas" (ribs) to the sides between the top and back linings to reinforce the sides against splitting. These are pieces of wood (normally Spanish Cedar) about 0,25" wide and semi-circular in cross section about every 6" and perpendicular to the grain of the sides. Jeronimo Pena Fernandez used these and it would seem a good idea on sides this thin.
Good luck,
Max
Max Bishop
Brighton, Michigan
PostPosted: Thu Apr 22, 2010 7:15 am
Last Name: Collins
City: Argyle
State: New York
Zip/Postal Code: 12809
I agree with Alex & Max.
Mike Collins
PostPosted: Thu Apr 22, 2010 7:49 am
First name: Martin
Last Name: Kominak
Country: Slovakia
thanks a lot! that's what I needed to know.
PostPosted: Thu Apr 22, 2010 7:50 am
First name: David
Last Name: LaPlante
If you are using Indian rosewood you may actually be closer than you think to the hard dense Cypress that the old makers had access to.
I don't have densiity figures at hand but I certainly think you are in the ballpark especially if you use the thicknesses Alex has given above.
Users browsing this forum: Bing [Bot], Woodie G and 59 guests
cron
