Need help with Rockwell drum sander http://luthiersforum.com/forum/viewtopic.php?f=10101&t=28153 |
Author: | Greenman [ Sat Jul 10, 2010 3:58 pm ] |
Post subject: | Need help with Rockwell drum sander |
Author: | Mike OMelia [ Sat Jul 10, 2010 7:55 pm ] |
I do not know your machine, but it does sound like you are pushing it too hard. What is the drum size and motor horse power? How long have you been using this machine? |
Author: | Lillian F-W [ Sat Jul 10, 2010 7:58 pm ] |
Post subject: | Re: Need help with Rockwell drum sander |
If I was to hazard a guess, I would say that your out feed table is not co-planer, causing your wood to rise as it exits. |
Author: | Howard Klepper [ Sun Jul 11, 2010 1:12 pm ] |
I nursed wood through one of those for years, and am glad I don't do that any more. It's 90% likely that you are hogging off too much. Actually, "hogging" is not in this machine's vocabulary. You can sand very accurately with one, though. The main thing is that on a wide piece of hardwood you can only take off a few thousandths at a time. That's right, 4 or 5 thousandths at a pass will max it out on a rosewood guitar back. The wood isn't warping, it just takes a few seconds before heat builds up and the machine bogs down. Try advancing the height adjustment wheel by about 1/12 of a turn per pass. Also, what grit are you using? Anything finer than 80 is going to have problems. Feed the piece at an angle to the grain, taking advantage of the open end, and you will get a lot less clogging of the paper with resins, if that becomes a problem (it will on tropical oily woods). Don't feed too slow; it's happier taking a lighter cut at a faster feed rate than vice versa. |
Author: | Greenman [ Wed Jul 14, 2010 3:14 pm ] |
Author: | Greenman [ Fri Sep 03, 2010 7:07 pm ] |
Author: | Burton LeGeyt [ Fri Sep 03, 2010 7:24 pm ] |
I had this happen once. Took the motor off and we all stared at it for a long time until someone pushed the overload button a LOT harder than anyone else had and it was all better. Eventually the table raising mechanism died and we still have had no luck keeping it working for more than a week or two, it just seizes up and the table is stuck. I agree too that it did stall easily. We changed the belt configuration and that did help but I can't remember what it was on and what it is on now. |
Author: | Greenman [ Fri Sep 03, 2010 7:39 pm ] |
Author: | Burton LeGeyt [ Fri Sep 03, 2010 7:45 pm ] |
Hey Bill! That is you. I am glad that worked. We felt kind of silly when all it was was that button but dang you really have to lean in to that thing. That sander is not so bad, when it was working well it was great. The one I have experience on was abused pretty good before I got to it so if you are good to it from the get go I think it is a good machine. Hope all is well with you Bill! |
