12-string radius?
http://luthiersforum.com/forum/viewtopic.php?f=10101&t=28400
Author:  Josh H [ Wed Jul 28, 2010 9:05 pm ]
Post subject:  12-string radius?
I've got a 12-string instrument that is getting close to where I will need to radius the board. I haven't done many 12s, and this one is unique in that it is a 12-string bouzouki/cistern type instrument (oh and did I mention it is a double-neck instrument with a 8-string bouzouki for the other neck). The scale is a bit over 22" and the nut width is 2 1/16". I usually use a straight 16" radius on my guitars, but I'm thinking I should probably go with a 20 on the 12-string. Do you agree?
I'll post some pics of the instrument when it is done.
Josh
Author:  KiwiCraig [ Thu Jul 29, 2010 1:43 am ]
Post subject:  Re: 12-string radius?
G'day Josh,
I like 16 " on steel string 6 stringers too , but because of the wider neck on a twelve ( 1 15/16 " in my case ) , I opted for a 20 " radius. It feels quite comfortable .
I went for a 24.9 " scale. With a wider neck, closer frets help in the playability. Thirteen frets to the body to help the neck cope with all that string pull.
A shared 6 pin bridge . 5 mm. (3/16" ) width saddle . Each string individually compensated which makes a big difference when playing up the neck . A joy to have an "in tune " twelve string
Author:  TonyKarol [ Thu Jul 29, 2010 8:27 am ]
Hey Josh .. dont know if you tried the 12 I had in Montreal, but it was 1 7/8 nut with a 16 inch radius .. plays like a dream to me (and a lot of people who tried it)
Author:  Josh H [ Thu Jul 29, 2010 9:42 am ]
Thanks guys,
Tony, I don't think I tried out your guitar at the show. I've also done 16" on a 12-string guitar and liked it, but becuase this neck is extra wide I think I'm going to go with the 20.
You can see a sneak peak of the instrument here. http://www.houseguitars.com/on-my-bench/double-neck-bouzouki
Josh
Author:  Josh H [ Thu Jul 29, 2010 9:44 am ]
Oh and Craig, great looking guitar! I really like what you did with the bridge.
Author:  KiwiCraig [ Thu Jul 29, 2010 6:51 pm ]
G'day again Josh,
I've just looked at this double neck on your site. It looks to be quite a challenge ,but a great looking instrument . I'm sure the new owner will be thrilled to bits. I personally think you're on the right track with the wider neck . Much less congested and easier to play. I know Alan C. uses 2 inches at the nut.
With 20 strings on the instrument you might want to consider the shared bridge pin method . I have found it to be very successful with many advantages.
In the Tutorials section , I prepared a comprehensive tute '6 pin 12 string bridge ' on the anzlf forum
http://www.anzlf.com/viewtopic.php?t=354
I used the oversize Stewmac Ebony bridge pins
Author:  jfmckenna [ Fri Jul 30, 2010 10:13 am ]
Beautiful looking saddle!
Just curious though what is the idea behind a more shallow radius for a wider board?
I use 16 on mine and it works out well for me.
Author:  Josh H [ Fri Jul 30, 2010 11:29 am ]
Hey Craig,
Thanks for posting the extra pics and the link. As this instrument is an archtop I won't be using a pinned bridge. Each neck will have it's own bridge and tailpiece. I will keep your idea in mind for when I am doing flattops. I've built a few guitar-bouzoukis with pinned bridges and I think it would work great on that kind of instrument.
Someone can probably do a better job of explaining how radius affects playability, but it seems to me that on a wider board (which is harder to get your hand around) it is easier to fret with a shallower raidus. Especially if you have short fingers.
