Need help with purfling conundrum http://luthiersforum.com/forum/viewtopic.php?f=10101&t=31158 |
Author: | MaxBishop [ Fri Feb 18, 2011 10:20 am ] |
Post subject: | Need help with purfling conundrum |
I am working on finishing up a myrtle/spruce flamenco guitar. I'm really pleased with the progress of the guitar so far. However, I have run into a peculiar problem. I was sanding the sides and about one inch of the purfling (white/black) between the top binding and side disappeared! And, wouldn't you know it - it is on the upper bout on the bass side, right under the player's nose. I am thinking I could use a thin kerf saw to clean out the area where the purfling was, then slide in and glue a flat veneer sandwich, cut away the excess and scrape level with the side. The purfling is 1.0 mm thick. Has anyone encountered a similar problem and/or have suggestions? I'm really excited about this guitar and had hoped to take it with me to Spain this summer for the flamenco seminar I attend annually. But, if I can't repair this problem satisfactorily I probably won't. Any help with this will be much appreciated. Thanks, Max |
Author: | WaddyThomson [ Fri Feb 18, 2011 10:39 am ] |
Post subject: | Re: Need help with purfling conundrum |
I have had the same problem on a couple of my guitars, Max. My repair, the first time, was unacceptable. It's hard to get a slot the right size, and be able to get the purfling in and have a clean joint with the purflings it butts up to. A saw might be the solution for cleaning out the slot, I didn't think of that. My solution the second time it happened was to chisel out the binding and purfling and re-do the one side. Worked fine, and was actually easier than cleaning out the slot and trying to get a good match up at the joints. |
Author: | David LaPlante [ Fri Feb 18, 2011 10:41 am ] |
I think an exacto knife used with a flexible metal straightedge (taped in place) will give you better cleaner edges on the channel than a saw. Make a tiny chisel by grinding a flat and beveled surface on a flat needle file to "square end" the cut at the point where the purfling is deep enough so you won't sand through it again. You should be able to make a very neat pocket to put in a replacement section. Done cleanly it wll be undetectable. |
Author: | MaxBishop [ Fri Feb 18, 2011 4:54 pm ] |
Thanks for the input, guys. Best Regards, Max |
