Uke top
http://luthiersforum.com/forum/viewtopic.php?f=10101&t=31294
Author:  Jimmy Caldwell [ Sun Feb 27, 2011 4:52 pm ]
Post subject:  Uke top
I'm considering using an old flamed mahogany back I have as a tenor ukulele top. This will be my first foray into the ukulele world, so I'm unsure if the top thickness will be sufficient (It's about .080). If it's too thin, I'll probably buy a koa top, but the mahogany is exceedingly well flamed, and would make a beautiful uke. Any thoughts?
Author:  Ken Franklin [ Sun Feb 27, 2011 7:12 pm ]
Post subject:  Re: Uke top
That is not too thin for a uke top.
Author:  ernie [ Sun Feb 27, 2011 8:55 pm ]
Hi .075 -.080 will work depending on your back and sides , a double side 2 thin pieces .045 will make a very stiff and rigid side. For more info on ukes check out my videos http://www.ateliertomi.com
Author:  Quine [ Mon Feb 28, 2011 1:31 pm ]
0.08 should be ok. Just be really careful with sanding. You'll probably want a sound hole patch if you do a rosette.
