How do you blow up an image to use as a plan http://luthiersforum.com/forum/viewtopic.php?f=10101&t=33322 |
Author: | oval soundhole [ Thu Aug 25, 2011 5:09 pm ] |
Post subject: | How do you blow up an image to use as a plan |
I seem to remember Hanns Brentrup was able to edit a photo of a 19" Larson super jumbo to help him make plans for his own guitar. I was wondering how one would do this. I would really like to build a guitar just like this Torres, but there are no plans for this instrument. Does anyone know of any way to make reliable plans (I really just need the outline and head stock, the bracing isn't that complicated) with only the pictures that are available? The Guitar http://www.vintageguitar.com/3434/anton ... rres-1863/ |
Author: | Jeff Highland [ Thu Aug 25, 2011 5:25 pm ] |
Post subject: | Re: How do you blow up an image to use as a plan |
I have been thinking I would like to build that too The body length is given in the text so I would print the front picture, trace outline and soundhole and then enlarge on a photocopier until it matches the length |
Author: | Michael.N. [ Thu Aug 25, 2011 5:28 pm ] |
It would be very helpful if you had the usual dimensions of body length, upper and lower bout width, width at waist. With those measurements (and a photo) it's quite possible to produce an outline that will be close enough to the original. Practice and a trained eye helps. i don't know if that photo is detailed enough to blow it up in software and then print it off. Just remember that the original instrument is not going to be symmetrical. It's very likely that no half of the Top or Back is going to match. The usual course is to choose one half that appears to you to be the most graceful or alternately you can average out the differences. |
Author: | Michael.N. [ Thu Aug 25, 2011 5:33 pm ] |
You could always e-mail Richard Brune. There's a very good chance that he took real life measurements of that Torres. |
Author: | Scott A [ Thu Aug 25, 2011 7:15 pm ] |
This might help http://myplace.frontier.com/~nostberg/plans/index.htm |
Author: | oval soundhole [ Thu Aug 25, 2011 7:21 pm ] |
Scott A wrote: It's a completely different guitar, but thanks anyway. |
Author: | Jeff Highland [ Thu Aug 25, 2011 7:23 pm ] |
Read the text on the web page, lots of dimensions listed |
Author: | Pat Hawley [ Thu Aug 25, 2011 7:49 pm ] |
Sounds like you could use the "Big Print" program from woodgears.ca. Here's the link: http://woodgears.ca/bigprint/index.html Pat |
Author: | Jim Kirby [ Thu Aug 25, 2011 8:00 pm ] |
Enlarging copier and 36" printer at Kinko's? |
Author: | Dave Stewart [ Thu Aug 25, 2011 9:01 pm ] |
If you have a cad program (I use turbocad) and max. dimensions (ie body length and lower bout), draw a rectangle in cad to those dimensions. Open the image you want to trace in "paint" or whatever, and crop exactly to the extremities of the body. Then import the image into the cad drawing and enlarge it so it just fits inside the rectangle. Outlines can now be traced full size & printed. (I draw little X's to help in overlapping sheets for full size patterns.) |
Author: | Jim Watts [ Thu Aug 25, 2011 10:12 pm ] |
I just pulled this into Solidworks and sketched on top of the photo scaled to a 16.75 body length per the text. I have it as a C sized pdf if any one would like it let me know, or better yet pm me and I can send you the file. You should be able to get it printed at any print shop for a few dollars. I'll try to attach it here if I can. The file is a half pattern of the left half with the sound hole location and diameter. Attachment: small torres half pattern.PDF
Author: | CharlieT [ Thu Aug 25, 2011 10:54 pm ] |
Deleted |
Author: | L. Presnall [ Fri Aug 26, 2011 8:38 am ] |
Sorry, couldn't resist... Attachment: how-to-draw-dynamite-sticks-tutorial-drawing.jpg
Author: | DennisK [ Fri Aug 26, 2011 10:11 am ] |
Wow, that's quite an interesting guitar there! I wouldn't have thought a 2mm top could handle a 25" scale without any fan bracing at all. Granted, the lute style no-saddle bridge means much less torque than usual. Looks like 0.8mm sides aren't such a good idea though ![]() Let us know how it turns out. I may just have to make one as well ![]() |
Author: | oval soundhole [ Fri Aug 26, 2011 3:04 pm ] |
Thanks everyone, I had both Charlie's and Jim's pdf files printed out at a local print shop and they look great. ![]() |
Author: | CharlieT [ Fri Aug 26, 2011 3:41 pm ] |
oval soundhole wrote: Thanks everyone, I had both Charlie's and Jim's pdf files printed out at a local print shop and they look great. ![]() Glad to hear it, Brian. I'm looking forward to see what you build ![]() |
Author: | Jim Watts [ Fri Aug 26, 2011 5:56 pm ] |
Looking forward to the build. |
Author: | Chris Paulick [ Sun Aug 28, 2011 9:59 am ] |
Also with a photo the lens will distort depending on it's placement. Best to get a tracing. But then again you only really need to be close to the body shape. As we all know the magic isn't in just making an exact copy of the shape. |
Author: | David LaPlante [ Sun Aug 28, 2011 10:25 am ] |
I've usually just brought the book with good photos to a copy shop and enlarged all the while checking the mm measurements. To find the dimensions of things like pegheads and bridge width/length as well as rosette measurements (important to a properly proportioned copy), find a good photo of the detail that's not foreshortened and use the measurement data in the book and a rule or calipers. use the following formula: X over Y equals X over Y (unkown dimension "X") (measured unknown dimension "X" on photo) over = over (known dimension "Y" as per data) (measured known dimension "Y" from photo) plug in your values, cross multiply and divide. Work in millimeters. |
Author: | Michael.N. [ Sun Aug 28, 2011 11:22 am ] |
Chris is correct. There is lens distortion which does complicate matters. Then again if you are within sensible limits I doubt that it will make much difference. Don't forget, the original instrument itself is probably not that accurate to the original template. |
Author: | Chris Paulick [ Sun Aug 28, 2011 1:43 pm ] |
Just as a note, if you are so inclinded and have a good picture on the computer you can zoom in on the pic until you have it at 100% and trace it off the screen. Just like I did in making stencils for a National in this YouTube. You can just skip the beginning and this technic is pretty much at the last two minutes. If you have the known bout and length measurements you can also correct the lens angle distortion some with photoshop or some simular programs. |
