| USING RIVAL POT FOR HHG http://luthiersforum.com/forum/viewtopic.php?f=10101&t=33499 |
| Author: | weslewis [ Mon Sep 12, 2011 8:29 am ] |
| Post subject: | USING RIVAL POT FOR HHG |
I have it set at the lowest setting, goes up to 155 then shuts off ...seems to have about a 15 degree range on heat...for anyone using a rival hot pot is this what you are experiencing????? |
| Author: | weslewis [ Mon Sep 12, 2011 8:53 am ] |
| Post subject: | Re: USING RIVAL POT FOR HHG |
in face lowest setting on 143 off 155 I would assume that there is a little room to work with the heat on HHG .... |
| Author: | ernie [ Mon Sep 12, 2011 9:01 am ] |
I use an old yard sale baby bottle warmer . looks like a mini crock pot consistently heats to 135-150. I use recycled baby food glass jars for HHG . It is frozen when not in use, just add water when defrosted. |
| Author: | banjopicks [ Mon Sep 12, 2011 9:03 am ] |
One thing I checked recently is placement of the thermometer. I get totally different readings with it inside the glue bottle vs in the water. I put stones in the bottle and it stays at a very constant temp. |
| Author: | violinvic [ Mon Sep 12, 2011 9:48 am ] |
I use the Hot Pot made by Sunbeam. I drilled a small hole in the top for a candy thermometer. I put a layer of marbles in it to keep the jar off of the bottom. I put the thermometer right in the glue. Works great. |
