How to remove a screwed up X brace http://luthiersforum.com/forum/viewtopic.php?f=10101&t=33853 |
Author: | micahmed [ Tue Oct 11, 2011 8:19 pm ] |
Post subject: | How to remove a screwed up X brace |
So after gluing my X brace on I realized I made it to tall ![]() ![]() so what the best way to remove it with out scrapping the top? |
Author: | StevenWheeler [ Tue Oct 11, 2011 8:24 pm ] |
Post subject: | Re: How to remove a screwed up X brace |
Keep carving. Chisel,plane, sand paper... |
Author: | Rod True [ Tue Oct 11, 2011 8:38 pm ] |
Why won't the joint be right? As long as you've got wood glued to wood and capped you should be just fine... ![]() Are you assuming that the joint between the two MUST be at the center between them??? Someone please tell me why you'd need to make the lap joint equal on both pieces....? |
Author: | David Newton [ Tue Oct 11, 2011 8:42 pm ] |
What Rod says, is True! Sorry, bad pun, but good advice. |
Author: | micahmed [ Tue Oct 11, 2011 11:22 pm ] |
I thought that the over lap has to be the same on both sides for strength. ![]() |
Author: | Mark Mc [ Wed Oct 12, 2011 5:11 am ] |
Nope, if the bracing is otherwise good - just too tall, I would just plane/chisel it down and then cap the joint. Can't see how that would be a problem. Mark |
Author: | micahmed [ Wed Oct 12, 2011 7:28 am ] |
Ah dang it!!! I already started to remove it and even cracked the edge of the top. Hopefully I can fix it. |
Author: | micahmed [ Wed Oct 12, 2011 4:48 pm ] |
I cracked the edge about 20 inches in then gain another inch in. should I use my lmi white glue or CA glue? |
Author: | Rod True [ Wed Oct 12, 2011 5:47 pm ] |
That crack sounds like you split the top in half... Use the LMI white to repair, CA doesn't fix cracks on soft wood well IMO. |
Author: | micahmed [ Wed Oct 12, 2011 6:37 pm ] |
Yeah it's a split. Didn't break it all of the way off tho |
Author: | Rod True [ Wed Oct 12, 2011 6:58 pm ] |
Well, work glue in the split as best you can without opening it up anymore. Put some weight on it and pull the pieces together. |
