Finishing quandary - need help http://luthiersforum.com/forum/viewtopic.php?f=10101&t=34425 |
Author: | Corky Long [ Thu Dec 01, 2011 10:10 pm ] |
Post subject: | Finishing quandary - need help |
So what if I like the feel of a Tru Oil neck, but lust for the gleam of a deep, buffed sprayed finish on the front and back of the headstock? Do any of you Tru-Oil neck polishers spray your headstocks?? Of so, how do you manage the overspray, or the margin between the two finishes? Am I making this too complicated? Will a deep, buffed Tru-Oil finish on the headstock look like "the real thing"? So far, after about a dozen coats of Tru Oil, it doesn't seem so. Tru Oil seems to look better on a curved surface than a flat one... Headstock looks a bit anemic, but the neck looks like the surface of a pond at dawn..... |
Author: | Michael Smith [ Thu Dec 01, 2011 11:47 pm ] |
Post subject: | Re: Finishing quandary - need help |
I true oil the neck and back of headstock. That transition could be problematic. I lacquer the top of the headstock. The transition doesn't seem to be a problem for me. I'm putting the final coats of true oil on last. If you don't pore fill the neck and put a couple coats of shellac on after that you will have to put 80 million coats of true oil on to get a decent finish and could have problems with true oil directly over epoxy as some have had. |
Author: | alan stassforth [ Fri Dec 02, 2011 12:08 am ] |
You've got tru oil on da headstock. Can't turn back now....... |
Author: | Ron Belanger [ Sat Dec 03, 2011 7:47 am ] |
I like to oil my necks - Waterlox. And I French Polish the headstock veneer. I apply the oil daily for a week or so and fp at the same time. works for me. |
Author: | Stuart Gort [ Sat Dec 03, 2011 12:39 pm ] |
Seems to me that due to adhesion issues the only way to acheive a transition between Tru-Oil and lacquer would be to fully finish the entire thing with lacquer and then artfully sand back the nitro in the transition area....back to wood....then apply the Tru-Oil. I thought about trying this before but I can never remember to spray test panels when I'm finishing a guitar. ![]() What's wrong with skipping the Tru-Oil and scuffing the back of the lacquered neck with 0000 steel wool? It has more or less the same feel and it seems fifty times easier. ![]() |
