Dovetail neck by hand
http://luthiersforum.com/forum/viewtopic.php?f=10101&t=34675
Author:  gosport [ Sat Dec 24, 2011 11:15 am ]
Post subject:  Dovetail neck by hand
Anyone know of any instructions for doing a dovetail neck by hand? Most of the instructions that I can find use a router and templates. Any pointers will be appreciated.
James
Author:  CharlieT [ Sat Dec 24, 2011 11:36 am ]
Post subject:  Re: Dovetail neck by hand
Here's one...
http://gicl.cs.drexel.edu/people/sevy/l ... joint.html
Author:  ernie [ Sat Dec 24, 2011 1:49 pm ]
Tage Frid has a tutorial in one of his books of how to cut a dovetail by hand . He uses a special ece/primus dovetailplane that tilts at 10 deg angle on either side and has a depth stop adjustment mechanism .The waste is removed with a vy sharp chisel.The book is put out by fine woodworking, and can be borrowed via your local or interlibrary loan
Author:  B. Howard [ Sat Dec 24, 2011 5:20 pm ]
For the block I would scribe out the lines and take the waste with a forstner bit, clear the bevels with a good sharp chisel. Would prefer a dovetail chisel to a bench chisel, but either could do the job. The neck is much easier, layout & saw with a good backsaw, maybe clean with a chisel depending on how good your saw is.
Author:  Tai Fu [ Sat Dec 24, 2011 7:44 pm ]
I've read about using a bandsaw to cut dovetails... I wonder if that would work...
Author:  Arnt Rian [ Mon Dec 26, 2011 9:35 am ]
I took some pictures when I did this archtop...
Marking the dovetail on the neck blank
Sawing just outside the lines
Result
Cutting the mortise in the body, before cutting the waste out (router, forstner bit, chisel will all work)
"Chalk fitting" the joint, chisel to fit
Using a centerline jig to check the sideways alignment. A straightedge is used to check the neck angle / projected string height over the top
When everything fits, the neck can be glued in with a single clamp
Author:  Chas Freeborn [ Mon Dec 26, 2011 1:15 pm ]
Very nice Riant!
There is a short section on Jimmy D'Aquisto building an archtop in the back of Irving Sloanes "Steel String Guitar Construction" book that is the same method as Riant, only using western style back saws.
-C
Author:  B. Howard [ Tue Dec 27, 2011 6:53 pm ]
Nice vise!
Author:  cphanna [ Tue Dec 27, 2011 6:54 pm ]
You bet it's a nice vise! Wow! It's so beautiful, I'd almost be scared to use it.
Author:  Joe Hill [ Tue Dec 27, 2011 8:37 pm ]
Mr. Rian,
The Plexiglas guide you are using ...is that for alignment of the neck and body?
Author:  Jim_H [ Tue Dec 27, 2011 8:42 pm ]
It is a centerline finder and bridge locator from Tracy Leveque at Luthiersuppliers.com
http://www.luthiersuppliers.com/products/p9.html
Author:  Joe Hill [ Tue Dec 27, 2011 9:23 pm ]
Thanks for the link and info that tool looks to be a real time saver Jim.
Author:  crazymanmichael [ Wed Dec 28, 2011 8:16 am ]
arnt, some things never change; in this case the wow factor in your work. always a pleasure to see the photos of your work.
Author:  Carey [ Wed Dec 28, 2011 2:19 pm ]
Hear, hear!
