neck block taper
http://luthiersforum.com/forum/viewtopic.php?f=10101&t=36827
Author:  segovia [ Sun Jun 17, 2012 2:00 pm ]
Post subject:  neck block taper
Hi
If my plan calls for neck block depth of 95mm do I make it slightly over to all for a taper on the face that will attach to the back ?
How do you calculate the taper or do I just make it all about 3mm over and take it off with the radius dish ?
J
Author:  John Arnold [ Sun Jun 17, 2012 7:31 pm ]
Post subject:  Re: neck block taper
That is my approach, though I don't use the dish. After gluing he block to the sides, I taper it with hand planes and a sanding block.
Author:  segovia [ Mon Jun 18, 2012 1:44 am ]
Thanks =, I am going to try this approach to gate the correct taper and radius
There is no mention of what the starting dimensions are, I'll add the 3mm
http://gicl.cs.drexel.edu/people/sevy/l ... ining.html
Regards
J
