Buffing EM6000 http://luthiersforum.com/forum/viewtopic.php?f=10101&t=36887 |
Author: | sdsollod [ Thu Jun 21, 2012 5:08 pm ] |
Post subject: | Buffing EM6000 |
I have finished spraying my latest build with EM6000. Not only is this the first time using EM6000, it's also the first time I have used a new Fuji HVLP system. I think I did pretty well for my first effort. ![]() - So, what do you think, should I plan to start wet sanding with 600 grit rather than 1000 or would 1000 be okay to start with? - Can I go from wet sanding with 1000 grit directly to buffing with medium compound or should I follow the 1000 with finer grits before buffing with medium compound? Do I need to use coarse compound? - Any comments on the Stew Mac foam pads and Colortone buffing paste? Is there something else I should use? Also - what about the drill buffer attachments from somewhere like Harbour Freight that have imitation sheep's wool (synthetic material, I presume). Are they okay or should I stay away from them? Thanks, Steve PS - I'll post photos when Im done... ![]() |
Author: | Ken C [ Thu Jun 21, 2012 5:11 pm ] |
Post subject: | Re: Buffing EM6000 |
I am not a fan of wet sanding this stuff. I know others have done so successfully, so I will let them respond. Glad your new spray gun worked for you! Congrats! Ken |
Author: | James W B [ Thu Jun 21, 2012 5:29 pm ] |
I`m with Ken .I`ll start dry sanding with 600 or 800 ,depending on how the final coats look.I`ll try to remove all the little shiny spots before moving on to the next grit.I`ll usually sand up to 1500.Don`t skip grits.I`ve tried all kinds of different buffing set ups .from ros ,grinders drills etc.The only thing I`ve ever been satisfied with is a big buffing set up.There`s nothing like the real deal.I like Menzerna, medium and then fine.I`ve learned that em 6000 takes very light buffing .No need to over do it. |
Author: | Dave Stewart [ Thu Jun 21, 2012 6:41 pm ] |
You'll probably be ok starting with 1000 and I feel you end up with a much better finish wet sanding much further( I go right up to 2000) before buffing. (Ken, I'm not much of a "fan" either ....min spirits stink! Results much better though IMO) I've only used Mez & a buffer so can't comment on the foam. |
Author: | Ken C [ Thu Jun 21, 2012 7:21 pm ] |
I agree with Dave that the finer the grit you start with the better. If your finish is smooth enough you can start with 1000, all the better! I do use foam pads for buffing. I use Lake Country foam pads and buff with Menzernas polishes. I use an orange pad with the 2L Pre polish paste and a white one with the PO-91E. I've used those pads for years and really haven't used anything else. But I am sure there are others out there. Ken |
Author: | sdsollod [ Fri Jun 22, 2012 10:17 am ] |
Okay - It appears that folks prefer to dry sand EM6000 rather then wet sand... Is that right? I thought that wet sanding helped to keep "goobers" (Robbie O'Brien expression) from forming under the sandpaper and other positive things... Is dry sanding better because EM6000 is water-based? I have used micromesh on previous biulds using Tru-oil and Deft waterbased in rattle cans (which I didn't like) and achieved a fairly nice shine, but I want to do better with this build using EM6000. |
Author: | Dave Stewart [ Fri Jun 22, 2012 11:06 am ] |
sdsollod wrote: Okay - It appears that folks prefer to dry sand EM6000 rather then wet sand... Is that right? . Well I certainly don't ......sorry if I was unclear. I'll gladly put up with the stink vs. dealing with the pills every 2 seconds! (ie EM6000 wet-sands great with mineral spirits!) (ps have you seen this? viewtopic.php?f=10101&t=36317&start=0&st=0&sk=t&sd=a ) |
Author: | Barry Daniels [ Mon Jun 25, 2012 10:51 am ] |
Get some of the Low Odor Mineral Spirits. If you dry sand you need to have the correct sandpaper to prevent corning. |
Author: | SteveSmith [ Mon Jun 25, 2012 1:43 pm ] |
I wet sand with low-odor mineral spirits. |
Author: | sdsollod [ Mon Jun 25, 2012 2:00 pm ] |
I have already purchased the low odor mineral spirits... I need to let the finish cure for another 3 weeks. I was planning to use micromesh. Will that be okay? |
Author: | Joe Beaver [ Wed Jun 27, 2012 1:45 am ] |
Can't speak to EM6000 but I do wet sand KTM9 and it works great. I just use water. I may try mineral spirits on the next one. And yes, have used micromesh and it works fine. I like to take the finish up to about 8000 then buff. It comes out pretty good |
