Anchoring Hanger Bolts
http://luthiersforum.com/forum/viewtopic.php?f=10101&t=37408
Author:  John Killin [ Sun Aug 12, 2012 2:24 pm ]
Post subject:  Anchoring Hanger Bolts
I’m about to attach my neck to my body using a butt joint with hanger bolts. For those hanger bolt users out there, do you use anything type of glue to “Lock” them into the neck like CA or Epoxy?
Author:  woody b [ Sun Aug 12, 2012 3:04 pm ]
Post subject:  Re: Anchoring Hanger Bolts
I don't think anything is necessary but I put a little hot hide glue on them, since my glue pot is always near by.
Author:  ChuckB [ Sun Aug 12, 2012 5:25 pm ]
I don't use any glue on hanger bolts. A 1/2" maple dowel installed through the heel providing cross grain for the theads to grab onto is more than sufficient.
Chuck
Author:  Mike OMelia [ Mon Aug 13, 2012 3:51 pm ]
Chuck
This is a great idea. I've had them pull out of mahogany end grain before. I've got one neck that I have been looking for a fix. This is it!
Thanks.
Author:  woody b [ Mon Aug 13, 2012 4:56 pm ]
I use a maple dowel, and always have. The glue isn't to keep the bolt from pulling out, it's to keep it from unscrewing when you unscrew the nut. I doubt it's necessary, but it doesn't hurt anything.
Author:  Bryan Bear [ Mon Aug 13, 2012 10:24 pm ]
I agree, the dowel should be all you need. But. . . I usually put in thin CA, because, well why not?
Author:  John Killin [ Mon Aug 13, 2012 11:22 pm ]
That is what I was thinking. I put in a maple dowel so structurally I think I'll be fine. But once the fret board is glued down, I'd rather not accidently unscrew the bolt from the neck.
I have a bit of time before I commit myself so I’ll weigh out the options and try not to over think it.
Author:  Jeffrey L. Suits [ Tue Aug 14, 2012 12:11 pm ]
Mine are all neck resets, not new builds. I wick water thin CA in after they're installed.
