Der Jung classical tuners http://luthiersforum.com/forum/viewtopic.php?f=10101&t=37472 |
Author: | WendyW [ Sat Aug 18, 2012 10:41 am ] |
Post subject: | Der Jung classical tuners |
Has anyone tried the inexpensive Der Jung tuners made in China? I ordered a set out of curiosity and they were nicer quality than I expected, except that the shafts are not quite 10mm. They are closer to 9.5mm. What effect will the smaller shaft size have if I mount them in a head with holes that are 10mm? |
Author: | Shaw [ Sat Aug 18, 2012 9:47 pm ] |
Post subject: | Re: Der Jung classical tuners |
The post will bend over time. |
Author: | Clay S. [ Sun Aug 19, 2012 7:28 am ] |
If you mount them so the rollers bear against the side of the hole nearest the nut you should be fine. A quarter of a millimeter all the way around for clearance shouldn't hurt anything. |
Author: | Eric Reid [ Sun Aug 19, 2012 1:57 pm ] |
The roller diameter isn't much of an issue, but the machining is a little rough. The base plates are plated steel. Overall, even the cheapest Gotohs are a better functioning tuner. |
