Black pearl in a Maple fretboard. http://luthiersforum.com/forum/viewtopic.php?f=10101&t=37479 |
Author: | brazil66 [ Sun Aug 19, 2012 2:02 pm ] |
Post subject: | Black pearl in a Maple fretboard. |
I'm doing some inlay on a Maple fretboard, using Black pearl (Tahiti)...and looking for any tips as to a filler / method to work with this combination. Would like it to be as effective as the black CA glue in ebony, if I can. A good tint for superglue with Maple? Thanks......Michael |
Author: | Kevin Mason [ Sun Aug 19, 2012 2:57 pm ] |
Post subject: | Re: Black pearl in a Maple fretboard. |
I use epoxy with a bit of lampblack, but I have never inlaid into maple. |
Author: | DennisK [ Sun Aug 19, 2012 6:00 pm ] |
Don't mess up ![]() Really, there is no filler that will look good on light colored woods. Black is probably your best bet, to match more with the pearl than the wood. But then it will look more like an uneven outline than something that was supposed to be there. Hide glue is another option. It's what I use for inlays, because it doesn't fill gaps entirely. Fills it most of the way up so it's not so shadowy, but leaves a dip that shows it for what it is, and is a nice natural looking amber color that doesn't draw attention. |
Author: | Quine [ Mon Aug 20, 2012 12:31 pm ] |
I've never found a good filler for maple. If you can get the inlay close then just fill the gaps with clear CA. Sometimes a plane shaving will fill a gap and be reasonably hard to see, but you can't get away with much slop in maple. |
Author: | Mark Groza [ Mon Aug 20, 2012 1:48 pm ] |
What design are you inlaying? If dots, it will look good with clear epoxy.If it's a random design, you won't get a tight looking inlay unless it's cnc'ed in there. |
Author: | theguitarwhisperer [ Mon Aug 20, 2012 2:28 pm ] |
Actually you want the filler to be the color of the background so the inlay shape is as well defined as possible. |
Author: | Rodger Knox [ Mon Aug 20, 2012 2:39 pm ] |
+1 on the "Don't mess up!" It can be done without CNC... |
Author: | brazil66 [ Mon Aug 20, 2012 3:27 pm ] |
Thanks for all the replies......I'm gonna rely on close registration....careful work, but, it would be nice to have a bullet in my pocket. yours..michael |
Author: | Eric Reid [ Mon Aug 20, 2012 3:56 pm ] |
Lacquer burn in sticks are one option. http://www.stewmac.com/shop/Finishing_supplies/Repair_and_touchup/Lacquer_Sticks.htmlTry mixing the white and light walnut sticks. Blend them together on a scrap piece until you get a good color match. Maple dust in white glue can work too. The only way I've found of keeping dark abrasive particles out of the dust is to use a clean file on end grain. You may want to add a little cornstarch to overcome the darkening that the glue causes, but if you make a dry mixture, and stick to white glue, it will come close. Here's hoping you don't get to try any of these. |
Author: | TimAllen [ Tue Aug 21, 2012 11:26 am ] |
Nice work, Rodger! |
