Binding Channnel Prep
http://luthiersforum.com/forum/viewtopic.php?f=10101&t=38144
Author:  Spyder [ Fri Nov 02, 2012 2:32 pm ]
Post subject:  Binding Channnel Prep
OK, now it is time to glue on my wood binding. I plan to use Titebond, as with most things on this build. But would Elmers white glue be a better choice?
And, should I do anything to the channel before gluing? I am wondering if it is worthwhile to seal it with shellac first.
Author:  meddlingfool [ Fri Nov 02, 2012 2:39 pm ]
Post subject:  Re: Binding Channnel Prep
I wouldn't shellac it if you plan to use wood glue....
Author:  Goodin [ Fri Nov 02, 2012 2:54 pm ]
Titebond works great. No shellac. You want clean wood surfaces for glue up. Make sure your shop is at 40-45% RH, your binding is bent to shape as close as possible without kinks, several strips of binding tape ripped up and ready to go, and just go for it!
Author:  Dave Stewart [ Fri Nov 02, 2012 3:16 pm ]
+1 for titebond orig. You remembered to knock off the inside corner of the binding, right?
Author:  Alain Desforges [ Fri Nov 02, 2012 3:52 pm ]
Ah, Dave beat me to it. Knock down (round out) that inner binding edge. Only use shellac if you're going the CA route.
Good luck!
Author:  Spyder [ Sat Nov 03, 2012 12:13 am ]
Yep, already took down the inside corner of the binding. I will do a bit of fine tuning tomorrow since Iv'e figured out how to bend the stuff. Can't wait to see how it turns out!
Author:  Mike Collins [ Sat Nov 03, 2012 4:44 pm ]
Have you done a dry fit yet?
Put the bindings on with no glue that is.
You may find some places that need to worked on.
Author:  Spyder [ Sat Nov 03, 2012 11:39 pm ]
Yep, did that this morning. One piece was. well, I found a piece of leftover broken binding long enough to remake that one. And another I was doing some fine tuning to, well it broke on me in another place. But I think i have it close enough to right (by checking dry fit) that I can glue it back together before I glue it in the channel. It was a clean break, and the curve was pretty much dead on when it snapped. Think that might work?
i figure the rest of the broken pieces I'll make a scarf joint and glue them together on the guitar.
Any other suggestions for the best way to handle multi-piece?
