What devices are you using to measure relative humidity? http://luthiersforum.com/forum/viewtopic.php?f=10101&t=38194 |
Author: | mcgeorgerl [ Wed Nov 07, 2012 5:58 pm ] |
Post subject: | What devices are you using to measure relative humidity? |
I need to start monitoring the humidity in my shop area. Winter is ahead and I'm down in a concrete basement... Are the digital hygrometers in the 50 buck range accurate enough in your experience? Do you prefer the analog or digital style? Is there a "prefered" maunfacturer? Thanks in advance. |
Author: | DennisK [ Wed Nov 07, 2012 6:07 pm ] |
Post subject: | Re: What devices are you using to measure relative humidity? |
Get the little digital one here http://www.burgessviolins.com/products.html. Cheap and accurate. |
Author: | Andy Birko [ Wed Nov 07, 2012 6:20 pm ] |
Here's some good info on hygrometers: viewtopic.php?f=10101&t=27087&p=364087&hilit=hygrometer+test#p364087 What I'd recommend is go ahead and buy a decent digital one but try and find someone with a verified psychrometer to test against. |
Author: | WudWerkr [ Wed Nov 07, 2012 11:33 pm ] |
bought two of the 14.95 jobs at waldo world and have had no issues at all. |
Author: | dberkowitz [ Thu Nov 08, 2012 6:08 am ] |
Luft C200. http://www.Abbeon.com/store/item.cfm?co ... &catid=520 |
Author: | B. Howard [ Thu Nov 08, 2012 6:13 am ] |
I buy hygrometers from cigar sellers. They generally have good prices on them, I like the digital ones. I check all mine for calibration once a year. You can buy a calibration kit from laboratory suppliers for a few bucks. Just put the device in the bag with the calibration pack, wait 24 hrs. and note the difference in the readings. I mark the unit with a + or - of whatever is needed to adjust the reading. |
Author: | John Coloccia [ Thu Nov 08, 2012 8:10 am ] |
I use this: http://www.extech.com/instruments/produ ... prodid=177 It can be re-calibrated though I haven't had to yet. I've gone through a lot of meters looking for a reasonable one that's not too expensive. They are notoriously crap. This ones seems to consistently work right out of the box. |
Author: | Goodin [ Thu Nov 08, 2012 9:37 am ] |
I use a dial hygrometer I took out of a fancy cigar box, along with what my dehumidifier reads. I put the dial hygrometer near my glue up station and adjust the dehumidifier until the hygrometer reads about 40-45% RH. I've been meaning to get a sling sycrometer (sp?) to test for accuracy but haven't done it yet. |
Author: | SteveSmith [ Thu Nov 08, 2012 10:00 am ] |
I'm using a calibrated Abbeon unit. A bit pricey but I trust it. I also have a sling psychrometer for calibrating. http://www.ambientweather.com/ababhtab169.html |
Author: | WudWerkr [ Thu Nov 08, 2012 11:12 am ] |
Relative Humidity huh ....... If I have that many RELATIVES around , I control the humidity by Kickin em OUT !! ![]() ![]() ![]() |
