Haven't built a SS in a while - suggestions?
http://luthiersforum.com/forum/viewtopic.php?f=10101&t=39033
Author:  Jim Kirby [ Sun Jan 20, 2013 7:54 pm ]
Post subject:  Haven't built a SS in a while - suggestions?
Hi everyone. I'm in the midst of finishing up a Barbero flamenco and a Romanillos classical, and have thought that it has been maybe 6 years since I've built a steel string, and I should do it again before I forget how (or to teach myself that I already have). I've gotten very attached to smaller body guitars - the Romanillos is probably about as small a post-Torres classical guitar as you are likely to find - and I'd like to pursue that in a steel string. I have a Larrivee parlor that I could copy but I'd rather do something with a full sized scale length. I've thought of a Gibson L-0. I don't know much about the smaller old Martins.
Any suggestions?
Author:  douglas ingram [ Sun Jan 20, 2013 9:42 pm ]
Post subject:  Re: Haven't built a SS in a while - suggestions?
Filippo Morelli wrote:
Single 0, 12 fret slot head. You'll fall in love...
Filippo
It would be hard to go wrong with that!
Author:  Trevor Gore [ Sun Jan 20, 2013 11:07 pm ]
Depends how small you want to go, but...
You can get a really full sound from a double 00 sized guitar; smaller and you begin to loose some of the bass. So without new moulds etc. (if you build with moulds) how about a classical body shape (which is much the same size as a 00) with a falcate braced steel string top, live back, heavy sides, etc., etc.? Here's one like that. Some more ideas on this page.
Author:  Jim Kirby [ Mon Jan 21, 2013 7:03 am ]
Thanks everyone. Are there any good size 0 plans floating around?
Trevor, I had thought about using the Romanillos plantilla - it's tight waist makes it look a little more like a steel string anyway. I use a solera with a sectional mold (in halves) bolted on, so I'd have to jig up again anyway - I don't see a way around doing that. All my present outside molds are for 000's or a slightly smaller than Martin dred-like thing.
Author:  LarryH [ Mon Jan 21, 2013 9:39 am ]
0-28VS Guitar Plans
http://ultimate-guitar-plans.com/tag/0- ... tar-plans/
Author:  Jim Kirby [ Mon Jan 21, 2013 12:54 pm ]
Trevor is correct - certainly it is easier to get bass from the 00. You can get a well balanced single 0, but it takes some care. That last one I did, I ran a bit extra string height, a redwood top lightly braced and a slightly longer scale length. It is very well balanced with good bass presence.
Jim drop me a PM. There are no single 0 plans but I can help, if that's the direction you decide to go.
Filippo
I certainly will if I decide to go that way. Thanks. I'm going to look at 0 and 00 dimensions relative to guitars I'm already building. Even if I have to build an outside mold, I will still have forms for laminating linings, etc. I like the idea of following Trevor's suggesting and voyaging off in to what, for me, would be the at-present unknown. (I have no great attachment to the idea of faithfully reproducing a dovetail joint, and would prefer to learn the bolt on heel and fingerboard approach anyway.)
Author:  SteveT [ Mon Jan 21, 2013 2:40 pm ]
Jim- I've built mostly classicals & recently have built a couple 12-fret 00's. They are fun to build & play. And, as others have said, the size is a good match to classicals, so they feel "right" to me.
Author:  Jim Kirby [ Mon Jan 21, 2013 4:33 pm ]
Jim you can do those bolt on necks with your classicals too ;-) ...
Filippo
Yeah, but so far I don't wanna. I like working with the Spanish heel. Of course, I could build the steel strings that way too and let someone else worry about it eek
Author:  Jeff Highland [ Mon Jan 21, 2013 4:48 pm ]
A 13 fret neck on a classical body works well for me.
Author:  Clay S. [ Mon Jan 21, 2013 4:48 pm ]
One of my favorite small bodied guitars is the Martin size 1. I have built a few with the 25.4 scale and they have turned out pretty nice. I may even have a simple bending form and outside mold you can borrow. I'm working in Wilmington, De. and pass through Newark most days.
Author:  Jim Kirby [ Mon Jan 21, 2013 7:29 pm ]
Now there's a possibility. I hesitate to borrow anything for actual use, as my time to finish projects can be quite long (that real work just gets in the way). But it would be great to have the opportunity to trace your form or template.
Author:  Jim Kirby [ Sat Jan 26, 2013 6:49 pm ]
Well, this is moving along. Don Williams very graciously sent me an autocad drawing, and we both agreed that it would be a great idea to try out some of the cocobola that he sold me 5 years ago (amazing how time flies by). Then, today Clay Schaefer dropped by, traded stories for a bit, and lent me his Size 1 outside mold and bending form. Thanks guys - I'm inspired now.
Let's see, what ongoing project do I procrastinate on first so I can start this one? Hmmm..... I guess it shouldn't be the classical that already has a waiting customer. Think I'll get that one done first.
