router bit that used for making classic guitar bridge
http://luthiersforum.com/forum/viewtopic.php?f=10101&t=39054
Author:  martinbandung [ Tue Jan 22, 2013 10:15 am ]
Post subject:  router bit that used for making classic guitar bridge
could you tell me what kind of router bit that used for making classic guitar bridge, or could you reference some website about making classical guitar bridge ? thank you ... :D
Author:  Steve Davis [ Tue Jan 22, 2013 10:55 am ]
Post subject:  Re: router bit that used for making classic guitar bridge
You can do the whole thing on a table saw.
I believe Bogdanovich does it that way
Much easier IMO
There is a tutorial by GaryL in that section of the board if you want to go with the router
Author:  WaddyThomson [ Tue Jan 22, 2013 2:08 pm ]
I do mine on a Radial Arm saw, then use a chisel to ramp the back of the saddle section, and a plane and file to round off the front. Pretty fast process, really.
Author:  Lincoln Goertzen [ Wed Jan 23, 2013 12:43 am ]
I made my bridge mainly on a tablesaw, too. I followed Robbie O'Brien's Youtube video, and even though I had to make a model, and scale everything down (it was a miniature classical I was making), I found the whole process to be enjoyable and move along pleasantly.
If I were to do it again, I would prefer the tablesaw. No jigs required, just setting up the saw.
Author:  Jim Kirby [ Wed Jan 23, 2013 8:01 am ]
Tablesaw. I have bridge-sized setup blocks that line up the position and depth of cuts for each different bridge I've made. It takes only a few minutes to get each bridge to the point where it is ready for the chisel and file work mentioned above.
