removing "gunk" from nitro finish http://luthiersforum.com/forum/viewtopic.php?f=10101&t=39317 |
Author: | ZekeM [ Mon Feb 11, 2013 6:05 pm ] |
Post subject: | removing |
Nitro does not get along with a lot of plastics/vinyl. It softens the finish and really can cause a mess. Never leave a nitro finished guitar on a stand with plastic/vinyl always have cloth between. This is not the first time I've heard of those suction cups leaving marks in nitro. Once you fix it I would suggest that the owner does not leave it attached. Instead just put it on and take it off when they are done. Here is a link to a similar circumstance on the AGF http://www.acousticguitarforum.com/forums/archive/index.php/t-270720.html |
Author: | Chris Pile [ Mon Feb 11, 2013 6:28 pm ] |
Post subject: | Re: removing "gunk" from nitro finish |
Usually lemon oil or naptha will take most gooey stuff off nitro. Warm, soapy water sometimes works, and I even used some Fast Orange once. If you are very careful.... you could try acetone, but you have to use very light pressure, not leaving the applicator (rag, or whatever) on the surface but a few seconds. Use as a last resort. |
Author: | Clay S. [ Mon Feb 11, 2013 6:30 pm ] |
If only the surface of the finish has been affected you may be able to lightly sand and rebuff that area |
Author: | B. Howard [ Mon Feb 11, 2013 8:00 pm ] |
If it is the type of reaction I have seen from some stands with foam rubber it has likely gone deep into the finish. Sand and buff may work, most likely will need a spot refinish. |
Author: | utarazo [ Tue Feb 12, 2013 11:57 am ] |
Thanks everyone for the help! I will try wet sanding and buffing it, because seems like nothing else worked! |
