Finishing Problem http://luthiersforum.com/forum/viewtopic.php?f=10101&t=39391 |
Author: | Rod True [ Mon Feb 18, 2013 11:28 am ] |
Post subject: | Finishing Problem |
That looks like blushing to me but you'd think if would be less localized. I'd let it sit for a month or more (set it up and play it though) to see if it clears up.... Can't really see if that's sand through from the picture. |
Author: | Jim Watts [ Mon Feb 18, 2013 2:03 pm ] |
Post subject: | Re: Finishing Problem |
Was it very humid when you sprayed? If so there's a good chance it's blushing like Rod indicated. |
Author: | jethro16 [ Mon Feb 18, 2013 2:20 pm ] |
It was actually around 30% when i sprayed. I only know that because the same week (after I sprayed) I decided to get my shop humidity under control. I'm going to spend some time in the shop this afternoon so I'll post anything else I might find. I also edited the first post so you could click on the picture to enlarge it. Thanks guys. Jeff |
Author: | Jim Watts [ Mon Feb 18, 2013 2:42 pm ] |
Well it's probably not blush then, unless it's amine blush from the epoxy, in which case it's likely to get worse, or a sand through like you think. |
Author: | Rod True [ Mon Feb 18, 2013 5:36 pm ] |
Looking at the bigger picture on my PC instead of my iPhone, it does look more like sand through to me. I don't know what amine blush is as I've not used epoxy to pore fill.....might want to do a search on it. Mind you, does it fully go away when you spray new coats on it? What's it look like before you sanded/buffed out, after waiting the 2 weeks (second time...)? If it wasn't there than you probably have sand through.... |
Author: | SteveSmith [ Mon Feb 18, 2013 7:03 pm ] |
Jeff, I think I would only wipe with a damp cloth between coats and only use the mineral spirits on final leveling. I would be concerned that you might get some contamination with the mineral spirits between coats. |
Author: | theguitarwhisperer [ Mon Feb 18, 2013 7:27 pm ] |
Totally looks like sand through to me, especially with the lighter spot in the middle of the dull circle. |
Author: | jethro16 [ Mon Feb 18, 2013 9:13 pm ] |
Thanks for the help guys. I wanted to be reasonably confident that I am fixing the right problem before I shot more top coats. As frustrating as this is, at least I know where to go with it. Thanks again. |
Author: | Ken C [ Tue Feb 19, 2013 11:00 pm ] |
Still fighting it, eh, Jeff?! Bummer! Could you see the spot before you level sanded prior to buffing? If not, I'd certainly attribute it to sand through. BTW, denatured alcohol is not the same as mineral spirits. You should be okay using DA, but I don't know for certain with respect to your poly whey stuff. I swab my EM6000 between coats using a cloth moistened with a 50/50 mix of DA and water. Never, ever had an issue. Ken |
Author: | jethro16 [ Tue Feb 19, 2013 11:41 pm ] |
Ken C wrote: Still fighting it, eh, Jeff?! Bummer! Could you see the spot before you level sanded prior to buffing? If not, I'd certainly attribute it to sand through. BTW, denatured alcohol is not the same as mineral spirits. You should be okay using DA, but I don't know for certain with respect to your poly whey stuff. I swab my EM6000 between coats using a cloth moistened with a 50/50 mix of DA and water. Never, ever had an issue. Ken Yep! Can't quite close the book on this one! I didn't buff it out this time, but yes I noticed the spot after level sanding and not before. After thinking about it since this weekend, it's not all that surprising that I sanded through there again because there were only 5 coats over that spot and no one would expect to just put 5 coats of waterborne finish on a guitar and not sand through. ![]() As far as the DA, what I've been doing is wiping down with that 50/50 mix (DA and water) like you said after I do any level or scuff sanding and then I spray the the DA left in the spray gun on the guitar before spraying the next coat of finish. As far as I can tell, that's been working out great. |
Author: | Colin North [ Wed Feb 20, 2013 7:13 am ] |
Were you using an ROS or hand sanding? |
Author: | jethro16 [ Wed Feb 20, 2013 8:20 am ] |
Hi Colin, I was handing sanding. I have a ROS but haven't used it for sanding finish yet. |
