Martin truss rod
http://luthiersforum.com/forum/viewtopic.php?f=10101&t=39482
Author:  crich [ Sun Feb 24, 2013 2:24 pm ]
Post subject:  Martin truss rod
So I thought I'd try a Martin truss rod after reading some threads. I ordered a 14 fret rod and imagine my surprise when it showed up 15 inches long, not including the adjusting nut. :( Clinton
Author:  Joe Beaver [ Sun Feb 24, 2013 4:53 pm ]
Post subject:  Re: Martin truss rod
I too ordered some Martin rods after reading that thread. 15 " without the nut sounds mighty big. I ordered mine from John Hall and they are 14" including the nut. I thought there were about 3/4" to short but John says they are good.
Author:  Joe Beaver [ Sun Feb 24, 2013 5:06 pm ]
Plus mine look different
Author:  bluescreek [ Sun Feb 24, 2013 6:39 pm ]
the first one is a martin 1 way rod.
Author:  crich [ Sun Feb 24, 2013 6:52 pm ]
So why is it so long? I need to return it anyways, I wanted a 2 way. Clinton
Author:  grumpy [ Sun Feb 24, 2013 7:11 pm ]
If you run the rod right to, and even under, the nut, it's about 14-3/4" to the end of Martin-style dovetail, but even if you don't run it all the way up under the nut, the rod will still be completely within the neck and neck block, with just the adjusting nut left protruding past the block, so you do, in fact, have the correct rod for a 14 fret neck(even if you use a butt joint). You don't want the adjusting nut buried inside the neck block...
Author:  bluescreek [ Mon Feb 25, 2013 6:34 am ]
The way Martin installed these was so the adjustment end was right behind the transverse brace.
Author:  LarryH [ Mon Feb 25, 2013 10:34 am ]
Here's a pic of a Martin, 12 fret, one way truss rod. It was considered too long in a previous thread ( viewtopic.php?f=10101&t=39384&hilit=truss ) but seems to have come out just right in this application.
Author:  crich [ Mon Feb 25, 2013 1:01 pm ]
Ok, that makes sense to me now. I don't know why they sent a one way, maybe I didn't place the order correctly, but I'm thinking of using it anyways. Clinton
