Fingerboard to spanish neck before soundboard http://luthiersforum.com/forum/viewtopic.php?f=10101&t=41245 |
Author: | WendyW [ Tue Aug 27, 2013 2:05 pm ] |
Post subject: | Fingerboard to spanish neck before soundboard |
Somewhere on the web I saw pictures of a construction sequence where a classical neck with slotted heel had the fingerboard attached and fretted before attaching the soundboard and placing on a solera. I can't figure out where I saw it. Has anyone else seen this, or attempted to build in that sequence? Wendy |
Author: | Jim Kirby [ Tue Aug 27, 2013 2:47 pm ] |
Post subject: | Re: Fingerboard to spanish neck before soundboard |
I am building one like that, but it is with an elevated fingerboard, so the soundboard ends up being glued to the neck extension during the body assembly. I was following instructions in one of the buildalongs on Mario's site, by Mick Lazar. It's basically a Greg Byers design, but with a tilted soundboard (like a Humphrey) rather than a bent one. |
Author: | WendyW [ Tue Aug 27, 2013 4:14 pm ] |
Jim, now that you mention Mick Lazar, that is where I saw the pictures. It is a very interesting build documentation that I have referred to for other parts of the build process. I'm wondering if there is a way to use that assembly sequence for the neck/fingerboard/soundboard for a non-elevated fingerboard? I hope you will post some pictures of your build. Thanks for the reply, Wendy |
Author: | Jim Kirby [ Wed Aug 28, 2013 5:59 am ] |
Wendy, I suppose that the method could be extended to a more conventional neck geometry, but there is so much work that goes into jigs that it probably wouldn't be enticing to most folks. It may do a better job of controlling neck and top geometry than a regular solera though - I usually have to plane my fretboard a little to get things right even though the solera geometry is nominally correct. I'll post pics when I get back to that build - I've had all I can handle doing more conventional builds and haven't had the time to make progress on it. I basically have the neck made, the jigs built, and the sides bent, and it's been that way for probably two years. Attachment: neck-2.JPG
Author: | Mike Collins [ Wed Aug 28, 2013 12:52 pm ] |
I would not use that construction method. But I'm old hat! How can you be sure of the neck to top angle? Plus you'd need to build a special work-board. I'm not saying it can't work! If you make a work-board & figure out by trial & error the problems associated with this type of build then go for it. And post your findings please. Mike |
Author: | Jim Kirby [ Wed Aug 28, 2013 4:07 pm ] |
Mike Collins wrote: I would not use that construction method. But I'm old hat! How can you be sure of the neck to top angle? Plus you'd need to build a special work-board. I'm not saying it can't work! If you make a work-board & figure out by trial & error the problems associated with this type of build then go for it. And post your findings please. Mike It is indeed a special workboard and form, details worked out to the nth degree. But I can't evaluate yet as I've never gotten a box together with it yet. LOTS of jig and fixture work. |
