Making Purfling http://luthiersforum.com/forum/viewtopic.php?f=10101&t=41616 |
Author: | EddieLee [ Tue Oct 08, 2013 3:44 pm ] |
Post subject: | Making Purfling |
This is my first try at making (at least in part) purfling. I have a 55 mil strip of cherry and I want to glue a piece of 20 mil thick BW purfling to side. What is the best way to do that? I am leaning toward using CA. If I use CA will it still bend ok in a bender with a heat blanket? |
Author: | Tim McKnight [ Tue Oct 08, 2013 4:07 pm ] |
Post subject: | Re: Making Purfling |
Titebond III works well. |
Author: | Bryan Bear [ Tue Oct 08, 2013 4:29 pm ] |
+1 on titebond III. I have bent split side pieces glued with CA, the glue held okay but the fumes were very irritating while bending. |
Author: | TonyKarol [ Tue Oct 08, 2013 5:29 pm ] |
titebond original is fine too .. all I use except fish glue on coco ... |
Author: | EddieLee [ Wed Oct 09, 2013 3:52 pm ] |
Thanks, but if you use titebond, how do you clamp up any thing that small. My thought is to assemble the cherry strip and the 2 BW strips and then bend it. That way I will have only the binding and 2 pieces of purfling to deal with when I bind the guitar. If I do not per-assemble it, I will have the binding plus 5 pieces of purfling flopping around during binding. That seem like a nightmare. |
Author: | Christophe Mineau [ Wed Oct 09, 2013 4:01 pm ] |
Hi, Have a look at this setup : http://www.grellier.fr/article.php?id=6&lang=en maybe it could help ? |
Author: | EddieLee [ Wed Oct 09, 2013 4:47 pm ] |
Thanks Chrisrophe. I think I could make something like that work. |
Author: | Doug Balzer [ Wed Oct 09, 2013 9:50 pm ] |
This thread is helpful to me as well. Any other approaches to glueing the purfling to the binding prior to bending? |
Author: | SteveSmith [ Thu Oct 10, 2013 6:56 am ] |
One way is to laminate a board of whatever height you want your binding and at least 3" wide with a layer of veneer then slice off pieces of appropriate width. That way I get enough for several guitars. I use fish glue. Here's one with the single layer of veneer. Attachment: DSC00058.JPG Edit: I should have read the original post closer - this won't help if you're trying to do narrow strips. |
