Glue the mortice and tenon? http://luthiersforum.com/forum/viewtopic.php?f=10101&t=42017 |
Author: | sdsollod [ Fri Nov 22, 2013 6:21 pm ] |
Post subject: | Glue the mortice and tenon? |
In the past I have glued the mortice and tenon on my bolt-on necks. Was that a big mistake? I was just reading Cumpiano (pg. 190) and he says that the mortice and tenon are not to be glued. The luthier I learned from glued his... I know some folks don't... Thanks, Steve |
Author: | Trevor Gore [ Fri Nov 22, 2013 7:14 pm ] |
Post subject: | Re: Glue the mortice and tenon? |
sdsollod wrote: In the past I have glued the mortice and tenon on my bolt-on necks. Was that a big mistake? I can't see any advantage in gluing and it defeats the advantages of the BO neck. The BO neck with glued fretboard extension allows a poor man's neck reset (flossing of the heel with the fretboard still glued down), but a double tenon, full bolt on, bolt off affair is not that hard to do and has the advantage of you being able to completely remove the neck in a couple of minutes without messing with glue joints and all the attendant risks. |
Author: | sdsollod [ Fri Nov 22, 2013 8:01 pm ] |
I guess gluing the joint is like wearing both suspenders and a belt... I hope I won't be sorry I glued those necks. I guess as long they don't need a reset I should be okay... Trevor - I've seen some other methods of fingerboard attachment but they look more complicated. |
Author: | Trevor Gore [ Fri Nov 22, 2013 8:34 pm ] |
sdsollod wrote: Trevor - I've seen some other methods of fingerboard attachment but they look more complicated. There's more to making a double tenon bolt on, no doubt about it, but really, it's not rocket surgery. It's also one of those trade off things. I save more than the time it takes to do the double tenon in fretting and set-up time. Best to look at the whole process. Tilt necks are similar - needs more careful work getting all the fits right but effectively zero set-up time. Fit a saddle at your designed string height above the soundboard and just dial up your action. And the user can dial up an action change in seconds. |
Author: | Clay S. [ Sat Nov 23, 2013 10:22 am ] |
"I guess gluing the joint is like wearing both suspenders and a belt.." I think it's more like wearing a chastity belt - you may not be able to get to some places easily you might like to in the future. ![]() |
Author: | Shaw [ Sat Nov 23, 2013 5:22 pm ] |
Martin glues theirs. They use a single bolt to aid in the gluing process. |
Author: | brazil66 [ Sat Nov 23, 2013 5:57 pm ] |
My teacher , years ago...glued mine also. I watched him do it, thinking "oh no"....but kept my mouth shut. Years later I wish he hadn't done that. In my opinion, it is not the right way (or necessary way) to do things. |
