| neck to body http://luthiersforum.com/forum/viewtopic.php?f=10101&t=43032 |
| Author: | weslewis [ Sun Mar 23, 2014 3:07 pm ] |
| Post subject: | neck to body |
On a wedge type body how are you handling the neck to body joint?? |
| Author: | meddlingfool [ Sun Mar 23, 2014 3:23 pm ] |
| Post subject: | Re: neck to body |
Why would it be any different? |
| Author: | Colin North [ Sun Mar 23, 2014 4:31 pm ] |
meddlingfool wrote: Why would it be any different? Same at the top, angled laterally at the heel. I presume this is what you are asking about weslewis? |
| Author: | Trevor Gore [ Sun Mar 23, 2014 5:33 pm ] |
Almost exactly the same. Just bevel the heel cap to match the back slope. |
| Author: | weslewis [ Sun Mar 23, 2014 6:06 pm ] |
here is what I did...in retopping this 12 string that I am working on, I induced a slight wedge so I enhanced the wedge to give it a try, that's when I started thinking about the neck joint, I can see angling the mortise when building a wedge to match the tenon , problem is the neck block is in place and the mortise is already perpendicular to the previous top and the bolt holes are already drilled so if I cut the tenon like I normally do on a table saw at 90 degree angles things wont match up right...my plan is to use a taper jig and cut the tenon offset , if this makes any sense..... so I was just wondering how you guys were tackling this angle during the build... |
| Author: | TonyKarol [ Sun Mar 23, 2014 7:01 pm ] |
Sounds like you need to cut the tenon at the same angle as the wedged top ... |
| Author: | weslewis [ Sun Mar 23, 2014 7:12 pm ] |
yes.. |
| Author: | weslewis [ Sun Mar 23, 2014 9:38 pm ] |
actually it was no big deal...I made a ply extension for my incra mitre guage cut the tenon at 2 degrees off set then set my table saw blade at a 5 degree angle and finished like normal... |
| Author: | Trevor Gore [ Sun Mar 23, 2014 10:13 pm ] |
On a new build, it's definitely easier to put the wedge on the back rather than the front, then all my usual tooling continues to work. Just need to finish off with the angled heel cap. |
| Author: | weslewis [ Sun Mar 23, 2014 10:25 pm ] |
that definitely makes sense....this being a rebuild ...just kinda ended up that way!!! coming out nice though , same one I mentioned on the anzlf site...using falcate bracing |
