Ovation with a broken neck http://luthiersforum.com/forum/viewtopic.php?f=10101&t=44525 |
Author: | jack [ Sat Nov 08, 2014 9:46 am ] |
Post subject: | Re: Ovation with a broken neck |
nice repair Brian ; I like your repair fixture too... |
Author: | Chris Pile [ Sat Nov 08, 2014 9:55 am ] |
Quote: nice repair Brian ; I like your repair fixture too... Times 2. Please tell us more about that jig.... I find it very intriguing. |
Author: | Alex Kleon [ Sat Nov 08, 2014 10:20 am ] |
Yes to the neck fixture, as well. Which epoxy did you use, Bryan? Alex |
Author: | B. Howard [ Sun Nov 09, 2014 7:44 am ] |
I have been using System 3's T-88 epoxy for these and it works very well. The jig has been further improved from what is pictured here. I had a rash of severed necks come in recently and needed to come up with an adjustable clamping system that could both provide alignment and some clamping force in the lengthwise direction while allowing access for other clamps as needed. There are two cork lined frames, one that clamps to the neck shaft and another that clamps to the headstock. Three rods between them allow for positioning the two pieces in relationship to each other as needed and can also provide clamping force in the direction of the neck which is always the toughest way to obtain any force. With the last set of mods ( not pictured) the whole thing can be set up and aligned dry, separated to have adhesive applied and then returned to the exact position of the dry fit. It is also very open to allow clean up of squeeze out and allow room to apply other means of clamping to pull the FB back down tight etc. |
Author: | Pat Hawley [ Sun Nov 09, 2014 8:07 am ] |
Thanks Brian. Any chance of getting one or two pictures of your latest jig? Pat |
Author: | Peebs [ Sun Nov 09, 2014 9:30 am ] |
Very nice jig. Nice repair. |
Author: | Chris Pile [ Sun Nov 09, 2014 10:16 am ] |
Time for a video, Brian. |
Author: | Kamusur [ Mon Nov 10, 2014 7:36 am ] |
Very nice piece of work on that jig, well done. Steve |
