| Improvised Tools http://luthiersforum.com/forum/viewtopic.php?f=10101&t=44626 |
| Author: | Mike OMelia [ Sat Nov 22, 2014 11:48 pm ] |
| Post subject: | Improvised Tools |
A tool based on another tool that you find is a go-to tool and would not make a lot of commercial sense to produce. Do you have any? I have one. Just one. Sand paper glued to a stiff (that part is important) card scraper. I find endless uses for it like trueing kerfed lining ends and neck setting (to name just a few uses.) What others exist? Mike |
| Author: | Doug Balzer [ Sun Nov 23, 2014 12:10 am ] |
| Post subject: | Re: Improvised Tools |
A fine file with one narrow edge ground flat as to enable nut slots (and many other applications) to be tweaked on only one edge of file. Sent from my iPad using Tapatalk |
| Author: | dzsmith [ Sun Nov 23, 2014 9:47 am ] |
This doohickey made from acrylic with a perpendicluar line scratched ito it. I use it all the time for layout and alignment. Dan |
| Author: | Pat Foster [ Sun Nov 23, 2014 10:15 am ] |
X-acto saw blade made into a flexible scraper. Pat |
| Author: | Ken Jones [ Sun Nov 23, 2014 10:46 am ] |
Granite-topped tablesaw used as a truing/flattening surface. I know it's not ground to as high a tolerance as my truing plate, but it's pretty darn flat. It also makes a good coaster... Ken Jones Mountain Song Guitars |
| Author: | Ken Jones [ Sun Nov 23, 2014 10:50 am ] |
And along the same lines as Pat's idea, the perennial favorite, a razor blade with a hook burnished into the edge. Makes an awesome little scraper for leveling drop fills and such. One of my most reached-for tools. Ken Jones Mountain Song Guitars |
| Author: | Ken Jones [ Sun Nov 23, 2014 10:51 am ] |
Oh, also, I like using a 4' rope light for inspecting guitar interiors. Ken Jones Mountain Song Guitars |
| Author: | cphanna [ Sun Nov 23, 2014 11:13 am ] |
1-foot lengths of PVC pipe in various diameters, used as sanding blocks. Lots and lots of small hardwood sticks in various widths, with the sides beveled like chisels--also used for sanding. A walnut stick about 3/16" thick with a shallow groove needle-filed along one edge--used with very fine sandpaper to re-crown frets. Mike, I really like your card scraper sanding plate. That's a great idea. |
| Author: | Mike OMelia [ Mon Nov 24, 2014 12:07 am ] |
Ok, I'm stealing the pvc pipe idea. That's awesome! |
| Author: | Tom West [ Wed Nov 26, 2014 5:12 pm ] |
![]() Had this dial indicator and spent the evening making this gauge. Not sure it qualifies. Tom |
| Author: | phil [ Wed Nov 26, 2014 5:53 pm ] |
Mike, I adhere sandpaper to the sticky side of the mylar pick guard material. It's a trick I picked up here on the forum I think. I use it for flossing the heel of the neck to the body. The sandpaper stays flexible but won't rip. Used the same 1" strip of 100 grit on at least 8 guitars by now. |
| Author: | Mike OMelia [ Wed Nov 26, 2014 8:25 pm ] |
Phil, that is a GOOD idea! Michael, like it a lot! Tom, what is that used for? Top thickness? The starting idea was to take an existing tool, adapt it to other purposes which are not commercially viable. Or, if they were commercially viable, they would be ridiculous expensive. |
| Author: | Tom West [ Wed Nov 26, 2014 8:37 pm ] |
Mike: Correct, checking plate thickness. It has a depth of about 9" so you can check up to 18"wide or so. Have never built any thing over about 16" though. I have a thickness sander and normally just check around perimeter but this will be nice to have anyway. Take care. Tom |
| Author: | Arnt Rian [ Thu Nov 27, 2014 7:55 am ] |
This is a pretty common one I guess, but I don't think I've seen a commercial one. I have seen lots of shop made versions though, which were the inspiration for mine: Binding scraper / thicknesser, made from an old plane iron (which could use some sharpening, oops...), a couple of bolts and some wood.
| Author: | violinvic [ Thu Nov 27, 2014 8:24 am ] |
A sharpened piece of scrap to clean glue squeeze out. |
| Author: | cphanna [ Thu Nov 27, 2014 9:54 am ] |
I think Arnt's binding scraper/thicknesser. Simple and very stout. Looks easy to adjust, too. |
| Author: | Hesh [ Thu Nov 27, 2014 10:44 am ] |
This is yet another David Collins idea that we use in our shop and I made one for my home shop too. The uses are countless and include a nice stable platform for crafting nuts and saddles or simply to beat the crap out of something like an Ov*tion..... There is more to the design than meets the eye too. The leather is important in providing a surface to dig one side of a file into for applications such as filing down, and flat, nut ends for that "built-in" feel that some manufacturers use for their nuts. It all started with a scrap 16lb chunk of steel to provide the weight and hardness. Lots of ways to make an anvil so your own creativity is the limit. |
| Author: | Hesh [ Thu Nov 27, 2014 10:48 am ] |
Here's an old favorite that lots of folks use: The half pencil which is excellent for marking the "do not cut below" point when making a nut. |
| Author: | David Collins [ Thu Nov 27, 2014 11:18 am ] |
I think it would take less time to count the non-improvised tools in our shop than the improvised ones. I think I do have an old screwdriver laying around somewhere that hasn't been modified. |
| Author: | Arnt Rian [ Thu Nov 27, 2014 6:22 pm ] |
David, I can relate. I even 'modified' the half pencil thing; with a handle consisting of a thin piece of wood superglued to the top, along its length... I have lots of re-purposed screwdrivers, spatulas, knives, files and the like. Not to mention the many not so pretty 'plywood & drywall screw' class single operation fixtures, lots of those! |
| Author: | Mike OMelia [ Sun Nov 30, 2014 1:17 am ] |
Someone once told me that if necessity was the mother of invention, then frustration was the father of progress. Progress requires frustration and inventive solutions. I've seen a bunch here! |
