How do you add colour to the neck?
http://luthiersforum.com/forum/viewtopic.php?f=10101&t=44630
Author:  Doug Balzer [ Sun Nov 23, 2014 3:21 pm ]
Post subject:  How do you add colour to the neck?
I love the look of the neck below. Can we have some of you weigh in on how you add some color/tint to a mahogany neck?
Author:  Glen H [ Sun Nov 23, 2014 3:44 pm ]
Post subject:  Re: How do you add colour to the neck?
Yea, that is cool. There are many ways to do this, but the one that I find easiest is to use the tints from Stewmac. I just mix it into the first couple of coats of nitro after sealing and pore filling. Very easy to work with. I tint most all the necks I build to darken the mahogany or sepelle, reducing the contrast with the body wood.
http://www.stewmac.com/Materials_and_Supplies/Finishing_Supplies/Colors_and_Tints_and_Stains/ColorTone_Liquid_Stains.html
Author:  Haans [ Sun Nov 23, 2014 3:52 pm ]
Looks to me he's laid down a base coat of yellow dye solution, and then starting with a mix of brown that doesn't overly darken the wood, has applied the brown starting at the edges (peghead and heel on neck) and basically started rubbing it into the yellow, always starting at the heal or P/H and as the dye dries, working toward the middle. Most likely either a water or alcohol base. I prefer alcohol, and some can be removed or blended with a cloth damp with alcohol. Same with the box, and a little yellow can also be added to the damp cloth to highlight if need be. Edges can be made darker by adding successive dyings or adding a bit of brown to the original dye mix. Relatively simple proceedure made complex by gaining experience...kinda like watercorloring. Very good pictorial in Roger Siminoff's mandolin book.
Author:  askins [ Sun Nov 23, 2014 7:29 pm ]
Beau did a YouTube video of that burst. I can't find it right now.
Author:  askins [ Sun Nov 23, 2014 7:42 pm ]
http://youtu.be/pNHDKqxZh8E
Author:  Haans [ Mon Nov 24, 2014 7:27 am ]
Just as I said. Better not to use full strength, but to mix into a diluted small amount and apply. Several applications are better and the risk is less that you might make a mistake.
Author:  WudWerkr [ Mon Nov 24, 2014 10:38 am ]
Ditto ! [:Y:]
Author:  cphanna [ Mon Nov 24, 2014 11:10 am ]
It might be dyed after pore filling. Or the neck might have been done with colored pore filler. It's hard to say from seeing these photos. I agree it's a nice effect.
Author:  whiskywill [ Mon Nov 24, 2014 11:32 am ]
I don't know how it's done and don't like it. It looks dirty.
Author:  George L [ Mon Nov 24, 2014 11:50 am ]
I've experimented with this method a bit and have had a hard time keeping the stain from darkening my light-colored purlings. I've tried sealing with shellac, masking with tape, scraping clean afterwards--all without fully satisfactory results. Any tips on how others approach this step would be greatly appreciated.
Best,
