Oxidation on Cocobolo http://luthiersforum.com/forum/viewtopic.php?f=10101&t=44857 |
Author: | Casey Cochran [ Mon Jan 05, 2015 5:34 pm ] |
Post subject: | Oxidation on Cocobolo |
I'm preparing a coco set and as I run it through the thickness sander some high spots are causing uneven oxidation removal. Does this need to be dealt with or will the finish even it out? ![]() |
Author: | TonyKarol [ Mon Jan 05, 2015 5:59 pm ] |
Post subject: | Re: Oxidation on Cocobolo |
You are likely going to sand and scrape after bending and putting the body together, so I wouldn't worry about it much ... just let the body sit around some and it will all oxidize back ... plus when you bend you will make some of the resins rise and bake on too .. that will change the colour some as well .. |
Author: | Glen H [ Mon Jan 05, 2015 6:01 pm ] |
Yep, nothing to worry about. |
Author: | Casey Cochran [ Mon Jan 05, 2015 7:18 pm ] |
Thanks! |
