Fretboard inlay before or after radiusing? http://luthiersforum.com/forum/viewtopic.php?f=10101&t=45141 |
Author: | kjaffrey [ Sat Feb 14, 2015 11:02 am ] |
Post subject: | Fretboard inlay before or after radiusing? |
Just curious as to what other people do. It is easier to mark and rout for inlays on a flat board, but it is easier to get the final depth correct if done after radiusing. Just curious if I have been doing it "wrong" all these years. Kent |
Author: | TripodBob [ Sat Feb 14, 2015 11:56 am ] |
Post subject: | Re: Fretboard inlay before or after radiusing? |
B4 |
Author: | Kevin Mason [ Sat Feb 14, 2015 12:12 pm ] |
After. Especially if your inlay spans the width of the board. In this case, if you radius after and your inlay is too thin, you lose the outside edges. Or if your shell is not through color, you lose the color on the outside edges. |
Author: | DennisK [ Sat Feb 14, 2015 12:27 pm ] |
Depends on the inlay. |
Author: | DannyV [ Sat Feb 14, 2015 12:37 pm ] |
There you go. 3 answers and they are all right. Isn't this fun. Any other questions. ![]() |
Author: | kjaffrey [ Sat Feb 14, 2015 12:41 pm ] |
That's pretty much exactly what I expected as I have done it both ways and run into issues either way. I'm getting ready to do some pearl lettering that spans the board so that made me curious. One questions for those that do it after is how do you mark the fretboard for cutting the cavity on a larger piece? If the piece is wide enough it won't sit flat on the board so it will me tough to scribe around. |
Author: | Pmaj7 [ Sat Feb 14, 2015 1:38 pm ] |
Depends on the thickness of the shell also. Damhikt |
Author: | giltzow [ Sat Feb 14, 2015 2:09 pm ] |
kjaffrey wrote: One questions for those that do it after is how do you mark the fretboard for cutting the cavity on a larger piece? If the piece is wide enough it won't sit flat on the board so it will me tough to scribe around. I copy the inlay. Cut it out and glue it to the fretboard. After the glue dries I put a thin coat of super glue on to harden up the copy. Route it out normally but with a small piece of tape on the bit to fan the frayed paper away. |
Author: | Tom West [ Sat Feb 14, 2015 3:05 pm ] |
After. |
Author: | Terence Kennedy [ Sat Feb 14, 2015 4:18 pm ] |
After for me. |
Author: | rtpipkin [ Sat Feb 14, 2015 4:20 pm ] |
DennisK wrote: Depends on the inlay. I think this is spot on. It depends on the inlay and the material being used. I've done inlays with reconstituted stone and wood before and had no problem at all. But I did an abalone osprey once with carefully arranged shell patterns depicting stripes on the wings. After sanding the patterns were completely different because I'd sanded through the layers of shell I'd originally selected. Very disappointing. So...for the record, now I prefer to do it after. |
Author: | Mike OMelia [ Sat Feb 14, 2015 8:03 pm ] |
I love questions and answer threads like this. ![]() |
Author: | RogerC108 [ Sat Feb 14, 2015 8:23 pm ] |
I use a 12" radius board and have done it both ways with no problems. My inlays are fairly small, though. |
Author: | Rodger Knox [ Mon Feb 16, 2015 12:41 pm ] |
Another alternative is to cut the routes a little deeper and completely cover the inlay with CA. Works well for bar style markers on a bass, or anything that is wide enough for the curvature to make a difference. |
Author: | kencierp [ Mon Feb 16, 2015 1:23 pm ] |
After |
Author: | Wayne Brown [ Mon Feb 16, 2015 5:20 pm ] |
After! |
Author: | dzsmith [ Mon Feb 16, 2015 6:58 pm ] |
I radius after inlay. I used some Abalone dots from China. After sanding, I had Pearl. Quite a mystery, huh? |
Author: | TimAllen [ Mon Feb 16, 2015 7:41 pm ] |
For large inlays, such as block inlays, I have read about radiusing first and then clamping the inlays in, flexing them to fit while the glue sets. I'd be afraid I'd crack the inlay trying this. Anyone have experience with this technique? |
Author: | John Arnold [ Tue Feb 17, 2015 12:03 am ] |
After. Sanding a pearl inlay too thin is no fun. |
