How do you remove wet-sand slurry?
http://luthiersforum.com/forum/viewtopic.php?f=10101&t=45189
Author:  dnf777 [ Thu Feb 19, 2015 4:36 pm ]
Post subject:  How do you remove wet-sand slurry?
Before I was converted, I wet sanded some waterbased finish and got that awful white powder slurry onto parts of the rosewood fretboard. Is there any trick to clean it off? The neck is pretty much complete (fretted ,inlayed all glued up) and ready to be bolted on.
thanks,
Author:  sdsollod [ Thu Feb 19, 2015 5:35 pm ]
Post subject:  Re: How do you remove wet-sand slurry?
I don't take the masking tape off my fingerboard until after buffing...
Author:  James Ringelspaugh [ Thu Feb 19, 2015 5:54 pm ]
An eraser? Fine steel wool? A little brass bristled brush?
Author:  kencierp [ Thu Feb 19, 2015 6:35 pm ]
Scrub it out with naphtha and a fine tooth brush.
Author:  dnf777 [ Fri Feb 20, 2015 6:20 am ]
Thanks. My default plan of steel wool and elbow grease did the trick. But from now on, masking tape isn't coming off until buffing is done! What a PITA!
