Side inlays http://luthiersforum.com/forum/viewtopic.php?f=10101&t=45704 |
Author: | PeterF [ Tue May 12, 2015 1:32 pm ] |
Post subject: | Side inlays |
I'm thinking about doing some side inlays on the uke I'm building, but I can't quite work out the best way to do them. Should you do them before bending the side or after? Before, you have the problem of the heat softening the glue and the corners of the inlay will cause stress risers that could start cracks while bending. After, there's the problem of how to get the router to sit on the curved surface. I'm leaning towards doing them after. Any thoughts? |
Author: | DennisK [ Tue May 12, 2015 2:36 pm ] |
Post subject: | Re: Side inlays |
What size of pieces? Anything in the waist, or just the convex areas? It's surprisingly easy to use a router on a convex surface. Since inlay routing requires such slow and careful movement anyway, there's plenty of time to adjust your tilt to stay perpendicular to the surface if you're doing large pieces that need to wrap around. Or if you're working with small pieces, then choose a center point, get the router perpendicular, and hold it at the same angle even when you move, to create a flat bottomed pocket for each piece. With large wrap-around pieces, you'll either need to start with thick wood and sand them to fit the curve of the pocket bottom, or use very shallow pockets and sliced veneers, which flex easily. If you're doing stuff in the waist... good luck ![]() If you want to see some really crazy curved surface work, check out the stuff Kevin Pederson does on his necks http://www.acousticguitarforum.com/forums/showthread.php?t=284337&page=17 Router work wouldn't be quite so easy on a curve that tight... |
Author: | PeterF [ Tue May 12, 2015 4:44 pm ] |
Thanks Dennis, that's pretty much what I had in my head, but it's good to be reassured I'm on the right track. I haven't decided on a design yet, just thinking about possibilities really. Kevin's the one that got me thinking about this in the first place! His work is absolutely insane ![]() |
