register pins http://luthiersforum.com/forum/viewtopic.php?f=10101&t=45786 |
Author: | Ruby50 [ Tue May 26, 2015 10:14 am ] |
Post subject: | register pins |
I am putting on a top and a back. I have used barbecue skewers (1/8") to register the top by going into the neck block under the fretboard and into the heel block so the hole in the top is within the purfling. I am not putting purfling on the back of this one - is there a way to use register pins for the back?? Ed |
Author: | Jim Watts [ Tue May 26, 2015 10:16 am ] |
Post subject: | Re: register pins |
I leave a excess tab on the plates, drill the pin holes into that and register them into my mold. |
Author: | Colin North [ Tue May 26, 2015 1:16 pm ] |
I've left a tab on the plates both end (you can offset them from the center line) and used Hide Glue to attach a small blocks to the body so pins can be registered into them. Just saw off the excess before trimming and use a chisel to remove the blocks down to just above the glue line. Then hot water takes the last traces off. You can also register small pins into the binding area, it's removed anyway, but I'm not brave enough for that. |
Author: | kencierp [ Tue May 26, 2015 1:49 pm ] |
I favor though brace ends top and back -- I found that when notches are done precisely the top and back are pretty much locked in place. If width-wise adjustment is necessary I use binding tape to keep the center-lines mated. |
Author: | tysam [ Tue May 26, 2015 6:28 pm ] |
I'm with Ken on this one......my bracing notches are what I use for lining up tops and backs for gluing as well. |
Author: | Ruby50 [ Wed May 27, 2015 6:12 am ] |
That's how I have been doing it on the few I have built, so I guess I keep on keepin' on. Thanks Ed |
