Scotch Brite pads for H&L 6" ROS
http://luthiersforum.com/forum/viewtopic.php?f=10101&t=46327
Author:  Mike OMelia [ Wed Sep 09, 2015 7:34 am ]
Post subject:  Scotch Brite pads for H&L 6" ROS
Are these available? Seems all 3m stuff is unavailable.
Author:  WudWerkr [ Wed Sep 09, 2015 8:42 am ]
Post subject:  Re: Scotch Brite pads for H&L 6" ROS
What are u using them for . We sell Scotch Brite , Just not 3m If its for fine buffing try cutting a 6"x 9" hand pad into a 6" dia.
Author:  klooker [ Wed Sep 09, 2015 9:42 am ]
Have you looked at the Mirka Abralon pads?
Author:  Mike OMelia [ Wed Sep 09, 2015 10:21 am ]
I want to remove epoxy nibs and fine sanding lines before finish spray without fear of going through to wood. I've used hand pads, lot of work, don't want to reinjure tennis elbow thing. Plan was to use low speed ROS. I thought 3M owned scotchbrite. Can Abralon pads be extremely unaggressive? I will look and see if my current pads will stick to my ROS
Author:  klooker [ Wed Sep 09, 2015 11:58 am ]
Abralon goes up to 4000 grit - on their scale of course.
Author:  hermit [ Wed Sep 09, 2015 12:09 pm ]
I think grit sizes are standard. My years in telescope making talking here. Sizes can be graded from the sieve they pass through down to how long it takes to settle out of solution for the really fine stuff when the sieve sizes get too small to be practicable. The sizes are still based on what sieve the 'would' have passed through.
