Hard water deposits
http://luthiersforum.com/forum/viewtopic.php?f=10101&t=46504
Author:  ernie [ Wed Oct 14, 2015 11:11 am ]
Post subject:  Hard water deposits
I have a metal trough for soaking sides/purfs/bindings prior to bending .There are a lot of nasty white crystalline looking deposits all over the bottom . What is the best way to dissolve and clean them. I had a similiar problem in st louis on a humidifier when large white clacium looking deposits would crud up everything Thanks gaah
Author:  DannyV [ Wed Oct 14, 2015 11:16 am ]
Post subject:  Re: Hard water deposits
Never used it but there's a product called CLR that makes the claim.
Author:  wbergman [ Wed Oct 14, 2015 11:33 am ]
Read the label. Some of these products can;not be used in certain metals.
Ordinarily these deposits are like limestone and acid will loosen or dissolve it.. A weak acid is vinegar. I soak humidifier wicks in vinegar, but I do that in a plastic dish.
You might keep these deposit to a minimum in a tray if you pour out all of the excess water and rinse it down after each use.
Author:  ernie [ Wed Oct 14, 2015 4:37 pm ]
That/s the problem .I forget an leave the water in. Will try t vinegar . It/s too tricky to dumpout water in the bsmt from the metal trough. Thanks
Author:  SteveSmith [ Wed Oct 14, 2015 6:17 pm ]
I use distilled water for anything like that - for exactly that reason.
Author:  unkabob [ Wed Oct 14, 2015 11:06 pm ]
How large is the trough?
Use water from your dehumidifier in the trough it is virtually distilled water. I would prefer a plastic trough if that is workable.
I use dehumidifier water in my spray bottle for wetting sides for bending and for washing out glue brushes.
Good luck
Bob :ugeek:
Author:  ernie [ Thu Oct 15, 2015 9:30 am ]
T hanks gud idea use distilled water .I no longer have a humidifier. I spoke to a sawyer and he says to let the wood cycle through heat , dryness/humidity . etc. But cannot verify his theory . He has a kiln an bandsaw mill
